Question about Quickie Wheelchairs Jay 2 J2 Cushion Cover Replacement Wheelchair Quickie
.The ammeter registers0,and the battery
  • farshmelt Jul 01, 2009
    This"expert's" answer makes no sense. He didn't even read my question. If you can't do better than this, please cancel the insurance that I bought from you this morning. Ray Smith
  • 66 Answers
You could go on ebay and type the model number ant the brand of the chair. Or you could take it to a specialist to have them fix it for you.
Posted on Jul 01, 2009
The batteries will not charge. The ammeter does not move,just stays at 0 all the time. I pulled the connectors off the ammeter and there is 24 volts going to the ammeter.Not sure if the meter is bad or the...
It is an AMP Meter (Amperes) and AMP's are relative to CURRENT, not Voltage. Voltage measurements are read by a VOLT Meter. W=Watts or work units. Like a 40 Watt Bulb. R=Resistance. If the Battery fails to charge, it is due to the cells degradation as they only last so long. From what you wrote, I assume you need to replace the Battery.
Feb 11, 2018 | Pride New Jazzy 600 Power Wheelchair by...
I have a Pride Jet 3 that I bought from a co-worker. They apparently had automotive batteries in it, and they died. I put new wheelchair batteries in, but when I go to charge it, the bottom row of lights...
use a standard 7.5 volt dc fuse the speed lights will not blink when charging only the battery level lights will Make sure that your batteries are installed correctly... There should be two cables running to the fuse located at the rear of your chair one wire should be attached to the positive post of the front battery and the other wire to the negative post of the rear battery. The other cables should be color coded red for the positive post of the rear battery and the black to the negative post of the front battery. This will connect your batteries in series so you will be getting 24 + volts to the chair. The chair should then come on with the power switch on the joystick all the battery level lights should light up and the speed level lights will light up indicating the speed level you are set on. Once you have made sure that the batteries are wired correctly plug in the charger cord and you should get some deflection on the ammeter. When the ammeter reaches zero and kinda bounces up and down then you should be fully charged Hope this helps
May 07, 2011 | Pride Jazzy 1113 ATS Indoor Power...
I bought an MPV5 used. Batteries won't charge. Charger light is green after 24 hours...slight power surge then dies. The seller said it hadn't been plugged in for a long time. I also noticed the batteries...
Lets solve this, one question at a time ....
First your batteries are not charging,This may be because of it siting for too long without a charge.The batteries may be so dead that your charger cannot reconize them. dont losse hope there are ways to check your batteries and charger with out spending alot of money on a tech coming over.
1) Unplug and remove your batteries from the chair
2) Find your self a charge that trickle charge
(Note: If you have a batterie charger ,trickle charge is the lowest set charge)
3) Trickle charge each batterie to about 50%
4) Install batteries back on to chair
5) Plug in chair charger
The chairs charger should come on ,and that right there tells you that you have a good charger!
The batteries that came with this chair are not bad and are considered ok to use .These type of batteries are what you call maintenance batteries ,which your always having to check if the leaking or need water.The gell type batteries are what they call non-maintenance.That you dont have to always look after but are more money.Thats why they recommend the gells so that the user doesn't have to work on there chair.
I hope that was helpful ,Happy Riding
Feb 10, 2011 | NRS Hoveround MPV 5 - Used Power...
New batteries won't charge on Jet3 Pride Chair. I've pushed the reset button and have voltage from the receptacle. Thanks if you can help!!
Lets make sure the all battery terminals have the correct cable ,heres a web sit that you can go on to double check.http://www.pridemobility.com/pdf/Owners_Manuals/US_Jazzy/US_Jet_3_Ultra_om.pdf
Page 40 shows a diagram that covers it all.
Next after confirming that everything is connected correct,plug the chair in like if you where going to charge it,
I want you to check your ammeter if the needle moves to the center of the gage your charging if not you may have a bad charger.
Good luck hope i was helpful
Jan 24, 2011 | Pride Mobility Products New Pride Mobility...
Jassy 1103, will not start charging the battery.\r...
the 1103 uses an onboard charger. Charger's life span is about 3 years; some fail in 6 months, some in 6 years keep in mind. You can charge the 1103 using an offboard charger which are available for about $50.00 on Ebay. Search for electric wheelchair charger. You want one that has a 4 to 6 amp rating.
The offboard charger has a 3-prong connector on one end and the other plugs into a grounded wall outlet. Plug the charger into an outlet and the three prong connector into the female three prong connector located at the bottom front of the joystick. Give it a good overnight charge and it should be back up to snuff in the morning.
May 21, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jazzy 1103 will not charge. Power cord and electrical outlet verified good. Plug in chair for charge, the ammeter indicator bar remains at 0, even after several minutes. If chair is powered on (while...
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
May 15, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jet 3 Ultra won't charge
Indeed, you need to find a repair shop. Try a google search for power chair repair, or ask your local hospital or if you can find one a power chair store. Most likely, you have a mechanical failure of the wiring, the battery themselves, or corrosion on the battery posts. Since the chair lights up when the charger is in, it is unlikely that the charger is broken. You may have a failure of the controller board, but that is also unlikely. And batteries do not usually suddenly fail completely; they typically fail slowly, losing the ability to completely charge.
I assume that you did not see a great deal of fluid leaking out of the battery container; you might look in the container and check to see if a battery is cracked or missing fluid.
Nov 10, 2008 | Jet 3 Ultra Power Chair
Check the fuses may have a Blown fuse
Regards; Aaron
Sep 16, 2008 | Jet 3 Ultra Power Chair
Quickie Wheelchairs Jay 2 J2 Cushion Cover Replacement Wheelchair Quickie Logo
56 people viewed this question
Top Quickie Wheelchairs Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Quickie Wheelchairs Health and Beauty Expert? Answer questions, earn points and help others
