Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
AMANA ARSE66MBW SIDE BY SIDE FREEZER COIL FINS GET TOO FROSTED ?
IS IT NORMAL FOR THE FREEZERS COIL TO GET MORE FROST AT THE TOP AND FORWARD HALF OF COIL WITH FROST CLOSING THE SPACE BETWEEN THE FINS, AND THE LOWER AND REAR HALF SHOW MUCH LESS FROST ?IN OTHER WORDS....IS THE COIL SUPPOSE TO FROST UP EVENLY OVER ENTIRE COIL AND ALSO LEAVE SPACE BETWEEN THE FINS IN THE COOLING MODE??ALSO...I WAS TOLD THAT MY FRIDGE HAS A SEALED SYSTEM AND IS NOT MADE TO BE CHARGED,BUT HAD A NON MFR CAP ON THE LINE WHICH SHOWED THAT SOMEONE HAD CHARGED IT.WHAT ARE YOUR THOUGHTS ON ALL OF THIS??THANKS!
  • 4,070 Answers
The frost should be uniform on the coils. Uneven frost pattern is a sign of low freon. Most systems are sealed but a qualified tech can recharge the system after finding the leak and cap it off.
Posted on Jul 01, 2009
Frost builts up in the coils
Frost will normally build up if you do not have frost free freezer and in which case it is possible the frost free system is faulty. If it is not frost free then it has to be defrosted a few times in a month. However if the frost comes up very quickly then there are possible causes.
You may be having leakage from the door seals or there are items in the freezer that are not properly covered to avoid moisture escaping. Other possibility is that your freezer is set too cold and there are not many items in it.
Aug 18, 2014 | Amana Freezers
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My Amana AFB2534DEW fridge is leaking onto floor, no visible leak coming from inside fridge or freezer. Unit does not have ice maker or water dispenser. Please help diagnose problem... Thanks
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Jan 07, 2010 | Amana AFB2534DE Bottom Freezer French Door...
Model gss25wg. 5 years old. Worked fine when we got it home. Now
Try to remove rear wall of freezer to check frost pattern. An even but light patter of frost on full coil is normal. Coils full of frost with aluminum almost fully hidden generally means defrost problem. Heavier frost on the bottom coils and gradually tapering off as you go up until the top coils have no frost usually means a leak of freon or a bad compressor.
Aug 22, 2009 | GE Profile 22.2 Cu. Ft. Side-by-Side...
I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
FREEZER WORKS BUT FRIDGE IS 50-55 DRGREES
if all that is ok then you need to check the heater and bi-metal / if it starts frosting up you loose air into the refrig side and the freezer will start going down too / frig side gets tem from freezer ,,,,, i bet you have a bad defrost heater / larry
Nov 29, 2008 | Amana ARSE664BS Side by Side Refrigerator
Amana fridge SRD27S4W 27CU.IN. 1995 S/S PARTIALLY COOLING
normal to have frost accumlulation, on the evaporator coil, not normal to see it coming thoughthe back panel, which is indictitive of defrost prblem, you can remove the back panel inside freezer compartment and look forthe thermostat( 2 wires leading to a round thermostat clipped onto the top coil of evap, simple to replace simply cut out old and wire in new one heres the part number R0161087
Nov 27, 2008 | Amana SXD524VW Side by Side Refrigerator
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
507 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
