Question about GE GDS18LBR Bottom Freezer Refrigerator
There is icing up in drip pan causing fan to stop working due to ice build up
  • 4,070 Answers
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
If the coils are also icing up you have an auto defrost problem.
Posted on Jul 01, 2009
    Problem Solver:
  • 5 Answers
To add to woodchucks solution, I did find that the drain tube on my GE fridge, a different model but similar design, had a snake-like shape and this section was having water get caught in it and freezing backing up my system. This section of the drain tube is covered by an insulated metal cover and by removing the cover the icing issue was eliminated.
Posted on May 22, 2011
Leaking in front of Refrigerator this morning took off front plate drip pan full looks like water over flowed from pan. no other leaks inside and out.
hum the drip pan should not get full as the heat from compressor. the way the drip system is suppose to work is that the heat causes the water to evaporate before it builds up to much in pan? Therefore u may be dripping to much water in line due to? is there a heavy build up of ice in freezer? if so bad defrost terminator or simply the cold control is set to high? the optimum setting for ur controls should be medium or half way
Mar 16, 2015 | Refrigerators
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff.
take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose.
Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.
The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser.
Possible that the condenser FAN stopped turning. That will ice up and melt at random:
see/hear that the fan is working.
If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
Nov 26, 2012 | Sub-Zero 700 Refrigerator Freezer...
My s21s4d fridge ice maker doesnt work, everything else is ok. the motor on the ice m/c doesnt seem to reset itself. how do i fix it.
Hi and welcome to FixYa, I am Kelly.
This appears to be a Whirlpool side by side unit. Commercial Code 858618353010 / Model S21S4D. If I got the brand incorrect please respond with your brand name.
I do not know your geographic location. I am assuming you are outside of the US.
There are a couple of troubleshooting links I will post here. Keep in mind that they are for US units but the only difference will be the operating voltage:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34 This is for the BASIC ice maker without optics.
And Job Aid R-92 (With optics)
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Note there are 2 different optics for these. Pre and post 2002. You will have to determine which one you have. The troubleshooting steps require that you TAPE the door / light switch in the depressed position. Ensure you read all of the set up steps.
Often ice makers stop cycling because the ice maker thermostat never reaches 14 - 16 Deg. F due to a problem with automatic defrosting. Ice builds up on the evaporator coils and air-flow in the freezer gets restricted. It will still freeze but won't make ice until the ice build up is excessive.
If you think you may have an automatic defrosting problem do a MANUAL defrost with an external fan by turning the unit off, removing the freezer contents and directing an external fan into the freezer compartment for just over 2 hours. (water mess so be ready)
While the fan is melting the ice in the freezer compartment... open the lower rear of the unit by removing the fiberboard cover and cleaning the condenser coils, condenser fan, the drip pan and the ver end of the compartment drain tube that terminates in the drip pan. Reinstall rear cover when complete.
After the 2 hours clean up the mess and return the unit to normal service. The unit should start making ice within 8 hours. It will operate normally for 2 days and then if the automatic defrost problem exists... ICEMAKER and freezer performance will degrade after 2 - 3 days.
Hopefully you have enough information now to troubleshoot your icemaker issue.
Thanks for choosing FixYa,
Kelly
Sep 09, 2011 | Refrigerators
I have a GE PTC22 fridge. I'm getting ice building in the freezer drain pan causing the evap fan to stop and things to get warm. I've cleared the 2 drains at the back left of the freezer, and is I see a...
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
Jan 31, 2011 | GE PTC22MFM Top Freezer Refrigerator
We are getting an overflow of water in the pan in the bottom of the refrig. What causes that and can the pan be removed to empty?
This may sound strange, but the cause of your problem may be your icemaker. The fill tube may be leaking before it gets to the ice maker and causing the pan uner the fridge to fill up too much. try turning your ice maker off for a few days and see if the issue stops. Or you can see if the tube is loose or iced up. If it is iced up, you may have a bad water valve. If you need more assistance, let me know. Hope this helps!
Dec 10, 2009 | Whirlpool ES5FHAXS Side by Side...
Whirlpool Defrost pan overflow
check and see if the door to the ice chute is closing all the way, moisture can get in there and cause excessive frost build up also check the location of your defrost thermostat behind the back panel in the freezer, it should be attached to the top of the evap coil. also check your water system and be sure that there are no leaks under the refer dripping into the pan while the unit is cycling for ice fill or dispenser line.
Sep 19, 2009 | Frigidaire FSC23F7D Side by Side...
LG Bottom Freezer Frost Issue
It sounds like your defrost controller has gone bad. I have an LFC25760 and had ice build up in the bottom of the freezer such that water would start leaking onto the floor. The ice build up in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
Jun 22, 2009 | LG LRFD25850 French Door Refrigerator
I have LG French Door Refrigerator Model LFC25760SB. I have the ice build up problem on the floor of the freezer. Is there a way I can only turn off the Freezer so that it can thaw to resolve the problem?...
George,
The short answer to your question is no. It sounds like you are having the same problem I had almost 1 year ago. The defrost controller in your fridge has gone bad. I have an LFC25760 and had ice buildup in the bottom of the freezer such that water would start leaking onto the floor. The ice buildup in the bottom of the freezer was due to a failing/bad defrost controller. Behind the back white wall in the freezer compartment exists the cooling fins along with a heating element underneath. Due to moisture that comes into the freezer from opening it, frost/ice builds up on the cooling fins. Thus the defrost controller turns on the heating element to melt the ice/frost off of the fins which then drips into a metal pan which channels the water to a drain hole which drops into the drip pan underneath the fridge next to the fan. The problem is that the defrost controller doesn't keep the heating element on long enough or the cooling cycle comes on too soon thereby freezing the water and plugging up the drain, which then causes the melted ice on subsequent defrost cycles to overflow the drip pan and flow into the bottom of the freezer and then eventually onto the floor when the bottom is full of ice. I had my defrost controller replaced (just outside the warranty period!) and it worked for about 1-month and then same thing happened again. Instead of paying for another defrost controller that would probably not work 100% my serviceman used the old paper-clip trick. He took a paper clip, stretched it out and then wrapped one end around the heating element and placed the other end into the drain hole. Thus when the heating element comes on the paper clip keeps the drain hole warm/hot and prevents the water from freezing. It has been 9 months since this fix and I haven't had any ice pooling in bottom of the freezer.
When I had the problem and started diagnosing it I opened up the freezer, pulled out the racks, draws, and eventually the door. Then I removed the ice maker and then a few screws and carefully removed the back white wall panel disconnecting the fan and any other electrical connections. Behind the panel you will see the cooling coil/fins, the heating element, the drip pan, and drain hole. Most likely you will see a sheet of ice everywhere. The best way to remove the ice is to boil a bunch of water in a tea kettle and slowly pour it on the ice to get it to melt so that you can start breaking out the pieces. Have a sponge and bucket ready to remove the water as the ice starts to melt. Eventually you should get all of the ice removed and get the drain hole unplugged. After all the ice is removed, you still need to fix the real problem by replacing the defrost controller, using the paper clip trick, or both.
Good-luck.
Jun 19, 2009 | LG LRFD25850 French Door Refrigerator
Drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
May 20, 2009 | Jenn-Air JCD2389G Side by Side...
Water puddling under the frigerator
I had the same problem. The problem was the drain tube from inside the freezer to the drain pan was partially plugged so ice was building up inside, then when the freezer went thru its defrost cycle large amounts of ice were melting. I fixed it by removing valve in the end of the drain hose, all ice inside freezer and ice in drain hose (pour hot tap water thru it).
Hopefully this helps.
Jan 22, 2009 | Refrigerators
GE GDS18LBR Bottom Freezer Refrigerator Logo
333 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
