Question about Compaq NX6110 TFT XGA Notebook
The display is not working on my compaq nx6110
I turned on the laptop and the screen was black. I reseeded the memory, cleaned the fan and restarted it. There was no change. I hope the display is not bad. Any suggestions?
  • ahmadnayef Nov 09, 2009
    dear Leekom;
    i have the same problem , but i get screen when i connect the laptop to external monitor , i think there is driver conflict , any idea what an i do ?
  • Compaq Master
  • 4,806 Answers
To rule out the graphics chip try plugging an external monitor to the laptop to see if you get a display through that, if you do it could be a loose wire or the inverter has failed.
Keep me informed for anymore advice if needed.
Regards
Posted on Jul 01, 2009
New memory nx6110
Did you remove and replace 1 or 2 RAM modules? There are 2 modules installed. One is internal and one is external. Both MUST BE OF THE SAME DENSITY OR THE LAPTOP WILL NOT WORK. You will need a second 1GB RAM Module, then use the link below to download the service manual for your laptop. Accessing the internal RAM module is fairly easy...follow the directions and you will have not problems. You CAN remove the internal one and operate the device on the single 1GB module, but I would recommend if you do that, you put the 1GB module in the internal slot. Then later, if you wish, you can add more RAM without additional disassembly. By doing this you will at least double your RAM from the 512MB you had to !GB. You can double it again with the second RAM Module to 2GB later.
.GO Here. Find Remove/Replace procedure for Internal Memory Module.
Nov 10, 2013 | HP Compaq nx6110 PC Laptop
Hp compaq laptop powers up and turns itself off after the post
Your laptop could be overheating. Try opening it up and cleaning all the dust that may have built up in the intake and exhaust fans.
Jan 16, 2013 | HP Compaq nx6110 PC Laptop
My compaq laptop F500 has black screen when power on
That sounds like a power supply problem. That would be the first thing I would check. If it was the processor, you would have heard a long beeping sound or if it was the memory you would hear about three 'annoying beeps'. The main reason you indicated there is no display on the screen and that the fan spins for a few seconds then shuts off, would hint that power is not going to the mother board long enough to spin the processor or cooling fan. Hope this helps :)
Apr 17, 2010 | Compaq Presario 700 470024-192 Notebook
The computer lights come up but the screen is black
check the connection that goes from the display to the laptop's motherboard most probably you have to change the display
Jul 26, 2009 | HP Compaq nx6110 PC Laptop
No graphics on the screen
press F8 key while turning on the laptop it will give you the advanced boot option select safe mode from the menu.It will take you to the safe mode , then do a system restore to the previous date when it was working fine
Jun 25, 2009 | HP Compaq nx6110 PC Laptop
Monitor screen stays black even though it's on
Remove the memory from your unit - power it up it should beep if full communication is still happening across your m/board. No beeps you board has died. if it beeps and your using two diffent memory modules just fitt one leave the battery out and power it up = if no display pull power swap out the memory and try again. if display occurrs you have a defective memory module - throw that failed unit away
glenn
Mar 07, 2009 | Compaq Computers & Internet
My laptop, hp compaq nx6110 has a screen problem. Its dim
OS?
Check the "Power Options" in your "Control Panel" (classic view). For whatever option you have picked, click "Change plan settings". There you can either "Restore default settings", or manually "Change advanced settings". If you choose "advanced settings", look for "Display" / "Display brightness".
Feb 26, 2009 | HP Compaq nx6110 PC Laptop
My compaq nx6110 screen goes black and on, why?
This is the issue with the monitor.This is a hardware issue.Please connect the notebook to external monitor and check .If it is working fine then it is the issue with the LCD of notebook If not then this is the issue with the video card.
And ckeck the power cables tooi think this is the issue with the monitor of the notebookAny how you can try to install the latest version of video drivers
Jan 08, 2009 | HP Compaq nx6110 PC Laptop
Compaq nx6110 laptop
hi, i changed an ic on the motherboard coz it mas not charging mnow the board wunt even switch on, the number of the ic i changed is HF5AJ do you have a solution as to what i can do????
Jun 22, 2008 | HP Compaq nx6110 PC Laptop
Compaq NX6110 BLANK SCREEN!!
Does the screen come on when computer posts and then go blank?
If so then try strting it in safe mode (F8)
Have seen this happen on a friends machine though it worked now and again until laptop was moved slighty. I dismanteled it and it turned out the motherbaord had liquid damage and was corroded :(
Sound like the onboard graphics is faulty...sorry not good news :(
Dec 26, 2007 | HP Compaq nx6110 PC Laptop
Computers & Internet Logo
186 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
