Question about Whirlpool Duet GHW9150P Front Load Washer
When i wash clothes it does not seem to have enough water in machine. should i be able to see water level. clothes are wet but no standing water
    Sergeant:
  • 353 Answers
Thats the beauty of these machines, they sip water and do a better cleaning job
Posted on Jul 01, 2009
Samsung WA422PRHDWR not filling with enough water
I find that some of my clothes don't seem to get wet enough to clean them properly. I like to use the pre-wash cycle to wet everything thoroughly then the machine goes through the normal wash cycle and it seems to do a better job. Just an idea.
Dec 08, 2012 | Samsung WA422PRHDWR
My front loading Samsung washing machine does not seem to have enough water in it during the wash cycle. In fact, you can not see any water at all. The clothing only appears to be moderately wet.
run the unit with no clothes in once it has stopped check the water level. in the rear of the tub the water hould be 3 1/2 inches deep and 14 inches wide.and will taper off towards the front of the drum.
Nov 28, 2010 | Samsung WF203ANW Front Load Washer
Washer seems to need more water.
HI, the water level switch(aka pressure switch), is responsible for regulating the water fill level in this situation. It does this through a plastic tube which runs from the switch in the control console down to the side of the outer tub, near the bottom . The tube is filled with air. As water enters the tub it also enters the tube. As water climbs inside the tube, it pushes on the air trapped inside and increases the air pressure. When the air pressure reaches a certain level, it triggers the switch.
I would advise to Inspect the air tube for kinks, breaks or damage. The tube should also be free of water. The tubing should be securely connected to the bottom of the outer tub and to the bottom of the water level switch. If there is water present, the switch must be replaced.
The water level switch has three connectors. Label and disconnect the wires from the switch. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. It will be necessary to test each of the three possible pairs. replace the switch if it fails the continuity test.
Feb 01, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Not enough water to wet all the clothes.
Either the water level switch has bad calibration or the water level tube has lost its air seal and needs to be refitted and air locked. If you do not know how to go about these tasks, call someone with experience. Goodluck, Macgivor
Jan 16, 2010 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Can't see water level at all
Yes very normal in a front loader for clothes to be dripping wet but you may see little to no standing water.
Nov 02, 2017 | GE WBVH6240F Front Load Washer
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Mar 29, 2009 | LG WM1814CW Front Load Washer
Water level problem with duet GHW9300WHP
The best way to check this problem is to run with no clothes in it the water fill and stop three time after the third time the water level should be high in the back tapering off to not much in the front this unit wash as a chemical wash not with a lot of water
Mar 28, 2009 | Whirlpool GHW9300 Duet Washer
Wash cycle water level
the water needed needs to just come up right under the door this is how much water they use cause they use a tumble wash to clean the clothes
low water preasure is a problem but also make sure both water inlets are being used (hot and cold) even if you dont have hot attach a y hose the machine needs both inlets in use
these machines use very low water usage but they still need a fill up point
Dec 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water level
The level of water in the drum is controlled by a pressure switch. This switch is attatched to the drum via an air tube which pushes air into the pressure switch as the machine fills with water. There could be a blockage in the pressure chamber attatched to the drum or the pressure switch is faulty.
Oct 31, 2007 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
118 people viewed this question
Dan Webster
Dan Webster
Sal De
