I have a HP 1215 that I have used for years. It still works great but squeaks so loud. I've cleaned everything I can reach. Is there something that needs oiled?
Yes, not to be rude, but obviously it needs lubrication if it squeaks (some parts may also be worn out); disassembly of such a printer may require special tools (my similar HP does) and my advice is that you seek pro help with it (and while they're at it, you should probably get a thorough cleaning and general overhaul incl. replacement of any rubber parts that cannot be cleaned with rubber cleaner). Years of service? Testament to HP printer quality, but it may have reached the end of its usable life and there are some decent printers out there for cheap. Nice if you can afford to buy American again--if you do, expect a long-lived replacement.
storm took my phone line out now my printer won't turn on there is a red light on in the printer and...
(More)
storm took my phone line out now my printer won't turn on there is a red light on in the printer and the power supply box has a green light on the phone repairman said the problem with the phone line was lightning
I have an HP910 just bought a few months ago. Now the on button blinks...the comp says cartridge...
(More)
I have an HP910 just bought a few months ago. Now the on button blinks...the comp says cartridge problem but the ink is both new. I think they may be dry already. Tnks.
i have a hp deskjet 1120c printer. it stops printing and sends a message "out of pasper" i...
(More)
I HAVE A HP DeskJet 1120C printer. It stops printing and sends a message "out of pasper" I punch the blinking yellow light & have to keep punching it to expell the paper. I turn the machine off - then back on - itstarts a new print cycle but this time it cuts the printing cycle even shorter. I believe I need a new set of gears & clutch assembly [on the left side of the printer]. What will it cost % where can I buy it? is there a serviceing org in or near Amarillo,TEXASwho is qualified to replace it?? It seems that the clutch disengeges while printing and will not reingage until the power is turned on again in another completely new printing cycle. Is there a way that the printing can be restarted after it stops to continue the original print cycle & save what has already printed. THANK YOU FOR ANY HELP YOU MAY OFFER. I REALLY ENJOY THE PRINTER !!! GENE HAMBY 5206 WESTGATE, AMARILLO,TEXAS 79106 806 354 2937 Email address: ehamby@sbcglobal.net
when a document is dumped from any other software the printer document feeds a sheet but doesn't...
(More)
when a document is dumped from any other software the printer document feeds a sheet but doesn't print at all...what's up with that?
i have a Canon IP 1800 printer.I ran out of colored ink but the black ink is full. When I try to...
(More)
i have a Canon IP 1800 printer.I ran out of colored ink but the black ink is full. When I try to print my printer keeps blinking and telling me I need ink. Is there anyway to bypass the colored ink and print with only black?
