Fan on outside unit will not turn on, will run once you give it a spin with a screwdriver however will not turn on by itself. Changed the fan and the capacitor both out with new ones, i am baffled!
  • 2 more comments
  • rizz27 Jul 01, 2009
    yes, the condenser unit has power, everything runs fine once I give the fan a little spin. it's when the unit turns off and then tries to come back on is when we have the issue? what could be causing this issue on the furnace board? thanks for your help by the way.
  • Mike McDowell May 11, 2010
    This is a stupid question(s) but....
    Do you have power to the condenser unit? Have you checked the fuses to verify that they are still good?
    If yes to above then go to then check the stat (is it calling for cooling?) just to be sure I would jumper out between R&Y at the furnace board.
  • 83 Answers
That is wierd. If the fan and capacitor is the same as the old one. Although I'm thinking of capacitor issue, you should take out the fan and capacitor and test it.
I hope this helps.
Posted on Jul 01, 2009
Ruud. How do I repair?
It is likely that the fan will have to be replaced.
Jul 13, 2015 | Heating & Cooling
Ruud UAKA-030JAZ fan spins, not blowing cold air
there are 3 things to be considered,first,if the compressor motor `s connectors are having loose,it gives a hi ampere to your RELAY that can cause to its contacts being fried,second,the compressor motor itself is gaining a hi ampere already i.e. having unusual sound that can cause heavy friction inside the turning mechanism and third the last but not the least,maybe this time,the tubes or the compressor itself having very small holes that causes to the refrigerant to escape and it doesn`t gives off cold air.
Apr 17, 2014 | Ruud Heating & Cooling
Fan on outside unit will not start
That could be a few different problems, does the unit sound like the compressor is trying to kick on? If so, it could just be the condensor coil...or the fan motor itself. I just had to replace the fan motor on my own outside unit. Check to see if the fan blade will turn with the unit both on, and off using a screwdriver or something.
Jul 15, 2012 | Heating & Cooling
Rheem condenser fan don't spin up under it'sown power.
If you have a multimeter that tests "uf" or "mfd" that is microfarads. That will test the capacitor. Turn off power to unit, touch top of cap with insulated screwdriver across terminals to discharge and remove fan and common. MARK WHICH WIRES GO WHERE. Or if no mfds on multimeter, amps×2650÷volts=mfd. Amp draw on fan wire off of cap times 2650 divided by the volts between common and fan on the cap. If cap is good it's likely the motor.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 12, 2017 | Heating & Cooling
The outside fan on the unit no coming on
Replace the fan motor capacitor (about $20) , that should solve the problem but if not , the fan motor has to be changed, make sure the new one has the same H.P.,same volts and same r.p.m.
Sep 24, 2009 | Heating & Cooling
Not outputting air
If this is a new problem after storage and you can hear a hum, you may want to unplug the unit and slip a screwdriver or something into the outside vents and see if the fan spins. My RV had this problem occur every spring and I had to manually spin the fan once and add a little lube to the bearing and it would work all season after that.
Jul 20, 2009 | Sharp AFS120NX Thru-Wall/Window Air...
Outside compressor fan won't spin without a nudge
either you can lubricate it by spraying wd40 on the bushings. Although usually fan motors are permanently lubricated there are still dust particles that get through and cause it not to spin.
May 21, 2009 | Carrier 38CKC024 Air Conditioner
C6 error code on LG art cool
Try turning the power off at the fuse box, waiting 5 minutes turning the system back on and spray some water on the vents on the side of the outside condenser. If the fan isnt spining get a twig and spin it in an anti-clockwise direction after 1 or 2 spins it should start spinning on its own. continue to hose the vents with water for another 5 minutes. Its important to have the fan spinning as it extracts the heat from the condenser box.
Jan 03, 2009 | LG LSC121PMA Split System Air Conditioner
Outside fan will not turn on
If you can spin the fan blade with a screwdriver or something and get it to take off you probably have a bad capacitor. If it will not turn then you probably have a bad motor.
Apr 02, 2008 | Goodman CKL24AR24 Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
