Question about Cell Phones
The answer machine quit working - Cell Phones
  • enviroserv Jul 01, 2009
    this ia cordless phone/answer maching for the home, not a cellular
    President:
  • 1,383 Answers
Reset all settings to factory defaults first.
Then again enabler answering machine.
Also give em your cell phone model information.
Thanks.
Posted on Jul 01, 2009
  • kishor
    kishor Jul 01, 2009
    For analog devices to work, like answering machines or normal
    telephones, they need to see "ringing voltage" coming from the service
    provider (ie. BellSouth). They send 48 volts DC downstream from the
    Central Office to your home.
    So check your service provider cable voltage to.
  • kishor
    kishor Jul 01, 2009
    The problem lies with not with your answering machine, but with your
    new digital phone service. For analog devices to work, like answering
    machines or normal telephones, they need to see "ringing voltage"
    coming from the service provider (ie. BellSouth). They send 48 volts
    DC downstream from the Central Office to your home. This voltage
    operates the ringers built into these analog devices.
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Roper washer model RAS8245EQ1 not working, buzzing noise
Her you'll find your answer..
http://www.appliancerepair.net/washing-machines-forward.html
Mar 08, 2013 | Roper Washing Machines
I have had this machine for quite some time but can no longer find the manual for it. One of the features allows me to retrieve messages from Can you tell me how to do this? I'd appreciate it.
Here is site for the manual to the 1725 answerng machine. I tried it and it works and you can print out the manual or just read it. Here you go:
http://dl.owneriq.net/9/9480d395-d537-9fc4-a562-229da0743f36.pdf
Hope this helps you, good luck. Barb
Dec 23, 2010 | AT&T 1725 Answering Machine
My hp 1040 will not pick up fax after the fifth ring answering machine picks after forth ring can't tell the between phone call or a fax used to before changed date on answering machine fax quite working
Set rings to answer
You can select the number of rings that will occur before the fax answers an incoming call. If you are using your machine as both a telephone and a fax machine, we suggest you set the ring count to at least 4 to give you time to answer.
TIP: HP 1050 Fax: The Toll Saver function for the Digital Message Center interacts with Rings to Answer. See Toll Saver on page 40. If you have the HP 1050 Fax and have Toll Saver turned on, set the Rings to Answer to 2.
1. Press Menu repeatedly until BASIC FAX displays and press Start/Enter.
Rings to Answer will display.
2. Press Start/Enter.
3. Enter the number of rings you want (2-7) and press Start/Enter.
The HP Fax rings the set number of times and then answers. It then produces a different sounding ring to alert you to which type of call is incoming.
• The additional ring may occur once for a fax call
• The additional ring occurs 5 times for a voice call. After the 5 additional rings, the answering machine will answer.
Dec 08, 2010 | HP 1040 Plain Paper Inkjet Fax
Answering machine doesnot work phone doesnot light up
I've had my GE 29879GE1-A corded phone for quite a long time, however, I never programed my answering machine cause I never received an instruction manual. It was given to me. I would like to know how to set it up and if it even works? The phone works fine. I need instructions for this product. Do You have a instructions manual or a manual for this product?
Aug 04, 2010 | GE 29879GE1 Corded Phone
Our AT&T 1725 has quit recognizing when the phone is ringing. The phone keeps own ringing instead of beign answered.
There are a couple of things to try. First is to check the cable & plug that connect the 1725 to the telephone line. Disconnect the phone line from the back of the answering machine, plug it into a known working telephone, using cell phone (or another land line) call the phone number and see if the phone rings.
If it doesn't, replace the line cord and try again.
If it does ring, check the optioning to make sure it is set for, say 2 rings.
Also, is the telephone line a regular telephone company POTS line or is it one that is being provided by a cable modem? If your phone service is being provided by a cable company, the media converter might not be putting out enough voltage for the answering machine to realize that the line is ringing.
If everything is correct, replace the answering machine.
Aug 18, 2009 | AT&T 1725 Answering Machine
Cell Phones Logo
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
