Question about E-Machines eMachines Desktop PC
No power to my emachine pc
I attempted to turn on my pc the other day and the power wouldnt come on. I noticed that the fan in the back is making a light noise but not spinning. The power light is on now but very dim. what could be the problem?
  • 1 more comment
  • Ciroc Nov 08, 2007
    I tried that....and there was no change in performance.
  • Ciroc Nov 09, 2007
    The fan in the back of the tower is not running either. When I push the power button nothing happends. the pwer light is very dim. I tried replacing the power supply, no change. But, the button is pushed it use to click on, now it doesn't. When I plug it in I can hear a very low hum coming from the tower.
    I used the same power supply which was 350. I noticed that the power light is on but very dim, is that any indication of the motherboard having problems.
  • 71 Answers
It sounds like there is something funny going on side the case since you replaced the power supply. First thing is to check for shorts. Blow out any dust inside the case and then try to reseat the memory and expansion cards.Also, be sure to ground yourself when touching the components.
If this doesn't work you can can pick up a SoYo Tech Aid card ( here ). It will show you whats actually going on while the computer is trying to POST and will help you narrow down the problem.
Posted on Nov 09, 2007
  • 317 Answers
You need to replace your power supply or have a technician do it. You can get one for $25-30.
Posted on Nov 08, 2007
  • Peter Burns Nov 09, 2007
    So it's the fan in back of your tower, not your power supply fan? Is that correct? You can also replace those, but it's not that big a deal if that one is not running. I've seen several new computers that don't even come with those.
    What is the wattage of the new power supply compared to the old one?
    It should be something like 350W or 400W. Just make sure the new one is not LESS wattage than the previous.
    If that's fine, there could be a bad connection with the motherboard.
T5020 emachine seems to have dead power supply- how can I confirm?
If the PSU fans only work for a short time usually this means that the PSU is shot
If you suspect your power supply has gone bad, there are a few basic things you can do to test it. First, plug the computer in and try to start up the computer. If the computer can start up or shows signs of having power (the hard drives spin up, or the fans turn on) the power supply might be fine, and you may have an issue with your motherboard or RAM. If the computer won't start at all, open the case and then turn the power supply on and attempt to start the computer. Observe the motherboard to see if any lights turn. If no lights turn on and there is no sign that power is being supplied to any of your devices, there's a decent chance that the power supply has burned out. If your computer experiences periodic crashing, feel the case near the power supply to see if it is hotter than normal, and smell the air. If the case is much hotter than normal or you smell burning, your power supply might be overheating, and may be damaged. hope this helps
Jan 01, 2013 | eMachines T5020 512MB DDR PC-3200 Desktop...
I am not hearing the fans on this computer and i notice it heats up very quickly
With the computer turned off unseat and reseat the fan connectors back to the motherboard. If the fans are still not turning on then try some other new fans. If new ones won't turn on then you know for sure at that point the motherboard is going bad because its not putting out a high enough voltage to turn the fans on.
May 21, 2011 | E-Machines eMachines Desktop PC
Emachines won't turn on
remove the processor,ram for 30min and put them back
May 30, 2009 | eMachines D3415 PC Desktop
Replaced dead power supply computer still dead
most power supplys are protected against faults when they are connected to damaged equipment
so it possibly just protecting its self
disconnect everything from the PSU except your MB
try to turn on
if your pc boots ok
re connect everythng else one thing at a time attempting to boot each time
when it wont boot you have found your fault
Feb 07, 2009 | E-Machines D2046 PC Desktop
Emachines W2888 not turning on
Easy fix! Sounds like you bought a bad Power supply. Purchase an identical and it will run like a car!
Jan 27, 2009 | E-Machines eMachines Desktop PC
Louder whirring noise when turning on computer
Usually on startup the fans work a little harder then slow down. On newer computers they still have noticable fan noise. Most of what ou hear while the machine is running after start up is the power supply fan. When it starts to go bad you'll hear it all the time.
Jan 09, 2009 | E-Machines eMachines Desktop PC
My pc wont work
Is the power supply fan running? Is the CPU fan running? Do you get any beeps when you power it on? Is the Monitor light green or red/ orange? Please answers these questions first so I can help you. Please don't rate me untill I am through with the answering your questions. I will be more than happy to help but first I need you to answers these questions.
Jun 10, 2008 | E-Machines eMachines Desktop PC
Emachines 1900+ gets power to the monitor and computer but wont boot
There could be a number of causes. Do you hear any beeps when the computer starts up? Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board. Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
E-Machines eMachines Desktop PC Logo
52 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
