Zonet KVM3002 2-port KVM Switch Logo
A
Anonymous Posted on Aug 18, 2014
What is DC input KVM3002 power Volt
What is the DC input 6V or something else
In moving I am unable to find the AC charger and plug cord for my Electric Houdini. This is brand new - never used !
What voltage is the AC ? 120V 60 Hz ??
Found this but it is for 120V 60 HZ
http://www.rabbitwine.com/replacement-parts/adapter-6-volt-2925-series-647771.html
however if your AC power is 240 volts 50Hz you need to keep looking !
What is an electric houndi - is it a electric cord screw ? this is my guess ?
Important note the 6v DC and the 80mA current rating on power AC- DC pack. If there is any marking on your Houdini similar make sure voltage is 6v DC and current is 80mA or less .
suggest you contact rabbit wine if your ac is 240 Volts and is not 120v 60 hz on the www,rabbitwine.com web site contact link or if DC voltage does not match. Or for advise on if it matches your device.
Where can i get a replacement adaptor
Radio shack, best buy or newark electronics.
What kind of plug adapter does my recorder take?
you will need a 6v or six volt power adapter to use a house hold electrical outlet. You can use it in your vehicle if your adapter can convert 12 volt dc to 6volt dc
What is the power supply for aomron blood pressure monitor hem712c
It uses the HEM-ADPT1, which is AC 100v-240v input and DC 6V 1Amp output.
Check Amazon for pricing.
2answers
6 Volt dc 4w charger for Omron blood pressure unit
You can use a multi voltage mains adapter for your Omron. These are available at electronic stores ot on the Internet. Make sure it is a DC adapter and switch to 6 volts also make sure the power connector is set correctly to the polarity of the Omron power socket.
2answers
I have a Sangean ATS 818cs portable radio but no 6v lead input
One note is the power plug going into the radio appears to be atypical in polarity. The center appears to be negative ( - ) instead of positive ( + ).
I have a 39 ford 6 volt battery operated car. I
you need a voltage doubler circuit which feeds from your 6V DC system and converts it to AC and steps it up and converts it to 12V DC. This device might be difficult to find. OR use a 6Vdc power inverter and just use a 120volt AC fan if much easier to source out in your area.
You might want to try a 12VDC high speed fan and see if the 50% reduced speed is already sufficient for you.
4helpful
What is the voltage on a Zonet kvm 3002
From the manual:
...please add a DC 5V~9V, 100mA~1A to the power jack. The power jack polarity is center positive.
9answers
Portable fm/am/sw radio
yes you did! you overstressed the components of the radio plugging a 6V instead of a 3V adapter!
Top Zonet Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
