Hi, I have a Canon Printer, model MP460, serial # JCYA53810. It will not print and an error message appears "The paper is jammed. Clear paper and press OK." I've cleared the paper and followed all instructions in the book. Any advice? Thanks, **** Byrnes
  • rguy325 Jul 01, 2009
    My problem as reported is still ongoing. I followed advice by putting settings to plain paper and fast. Error message still appears and printer won't print.
    Thanks,
    **** Byrnes
    President:
  • 1,952 Answers
Paper is jammed in the paper path or the paper jam sensor at the rear of the fusing assembly may be stuck, causing a false paper jam warning. Remove jammed paper. While clearing paper jams the top cover or rear cover must be opened and closed again before pressing Continue or online to resume. Check that the rear cover is closed; an open rear cover may cause a paper jam. If no paper jam is found, check locations shown in the user's manual. P Paper is jammed in the top or rear of the printer. Clear jam and press Continue or Online to resume printing. To prevent further jams, verify the rear door is closed securely. A false paper jam message will occur if the printer's back door is open. If message persists, the printer could have a defective paper jam sensor and service would be required.
Posted on Jul 01, 2009
  • 3 more comments
  • mohammed marika thambi
    mohammed marika thambi Jul 01, 2009
    required
    4P, 4MP
    have a paper jam, used garage air compressor to blow out the
    inside and also the paper tray area. I didn't see any bits of paper or
    debris come loose, but it worked..
    static.compusa.com/.../Canon-PIXMA-MX300-QuickStart-Instructions.pdf try this link
    page no 87, 88 ur problemsolved
    You can access Canon online support info here. Enter paper jam as a search, then choose #4 to remove the obstruction.
    Also see this:
    Issue: Paper is jammed inside the printer
    Solution: Removing paper jams MP600
    Removing Obstructions or Jammed Paper
    If [Paper output slot - The paper is jammed. Clear the paper and press
    OK] appears on the LCD, follow this procedure to clear the paper jam
    Clearing paper jams from the auto sheet feeder (ASF) or paper output slot
    Clearing paper jams inside the printer
    Clearing credit card-sized or 4" x 6" paper jammed inside the printer
    ASF / Paper Output Slot
    1. Turn off the printer.
    2. Remove paper from the ASF.
    3. Gently pull the jammed paper out.
      1. If paper is visible from the ASF, use both hands to pull the paper out slowly.
      2. If paper is visible from the paper output slot, use both hands to pull the paper out slowly.
        1. The above illustration shows a PIXMA MP500.
      3. If the paper tears and a piece of that remains inside
        the printer, open the scanning unit (printer cover) and remove the
        paper from inside the printer.
        Note:
        Be careful not to touch the components inside the printer.
      4. Turn on the printer and confirm that the Alarm light is off.
        (If the jammed paper remains in the printer, the paper may be automatically ejected.)
      5. Load paper back into the ASF.
      6. Press to clear the message and continue printing. If you are
        printing from an application software, follow the instructions
        displayed on your computer.
    1. Turn off the printer and disconnect the power cord and USB cable.
    2. Remove the jammed paper slowly using the following procedure.
      1. Open the rear cover to check if the paper is jammed.
      2. Pull out the cassette and check if the paper is jammed inside the cassette area.
      3. Stand the printer with the left side down, holding the document cover.
      4. Press the tabs together and pull the green cover toward you.
      5. Check if the paper is jammed.
        (If you were not doing Duplex printing, you do not have to follow this procedure.)
      6. Close the green cover and place the printer back to a normal position.
    3. Reconnect the power cord and power on the printer. Confirm the Alarm light is off.
    4. Load paper back into the ASF or cassette.
    5. Press to clear the message and continue printing. If you are
    Top
    mohammed marika thambi Jul 02, 2009
    i sure u buy wrong cartridge for your MP460...if u want higher quality,
    u should buy CL-51 cartridge for colour and CL-50 for black..
    fyi, CL-52 can only suitable for IP6210D / IP6220D printer. u can see yourself at this link :
    http://www.canon.com.my/section/inkjetPr...
    If you've already cleanup the cartridges try the followings
    1. Turn off printer
    2. Hold down Resume button and press Power button.
    3. Keep holding down Power button and let Resume button go.
    4. Press Resume button 2 times then let BOTH buttons go.
    5. Green lights will flash and then stop blinking.
    6. When green lights are solid, press the Resume button 4 times.
    7. Press the Power button and the printer should turn off, if not,
    press the Power button once more.
    8. Your printer should respond as normal..
    Please let me know if this work for you
    then
    Press ON/OFF switch to reset the multifunction device
    2.
    Removing paper jams MP450 / MP460
    3.
    The MP460 may require repair
    heres the problems currently with mp460 and at bottom is the link
    http://www.usa.canon.com/consumer/contro...
    this is the solutions for the mp460
    for the guest
    clean out your ink absorber after unplug
    reset printer you still have a little credit card sized paper in your printer that you need to remove it
    Brigadier General:
  • 3,917 Answers
I was having the same problem. Talk about frustrating. Sometimes up to 45 min of dicking around to get it to print one page. Here is what I did. And I know it sounds crazy but it worked for me....
SOLUTIONL: Cancel any currently pending print jobs. Press the settings button. Arrow down below the paper type setting (currently set to "Plain paper") and change the speed from "Standard" to "Fast". This did the trick for me and now I am feeding paper and printing like a mad man.
It really doesn't make complete sense to me why this would fix the problem and why so many people are having the same problem... but my rationale is as follows.... This is happening to many people ... not merely an isolated incident... so most likely this is an engineering defect. Something in the way they designed and built this thing is less than perfect. I am guessing that somewhere within the firmware that runs this printer there is a section that says start counting the number of milliseconds from the time the paper feed is started until it is place to begin printing (probably a sensor somewhere), and if too much time has passed then there must have been a paper jam. This allotment of time may have been set to a very small window of time...(tighter tolerances usually means better quality, but not in this instance.) So by setting the speed to "Fast" we are able to get the paper in position before the window of time expires.
Thanks for contacting Fixya.
After clearing a paper jam on my MP460, I get another error message, 'the paper is jammed. Clear the paper and press [ok]', which can't be removed. Pressing [ok] has no effect and I can't get into the main...
A few possible solutions:
- Open the top of the printer and look along the print path for pieces of paper.
- Press the reset button.
- Turn off the printer first and then unplug it. Plug it back in and turn it on. Wait for it to start up.
Bot
Apr 12, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Every time I try to print, the printer grabs the paper crooked.
There's a leaver where the paper comes out, make certain it's to the left when printing with paper and to the right for envelopes.
Jun 14, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon MP460 Paper Jam
this is only a possible solution.make sure the paper is between 17  to 24 pounds thick.i once had a jamming problem and it turned out to be the printer which canon replaced under warranty.but in the process i learned paper thickness can make a difference. i was recommended 20 pounds by a staples employee.i hope this helps you.
Apr 07, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Jamming problem
try this
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Error code 5100 - can't clear it
Lift up below the display screen.The printer top will raise up and a arm will lock into place.Make sure the ink cartriages are firmly in place,snaped into position,sitting flat.Lift arm out of the way and close the lid.Worked for me ,good luck.
Oct 07, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon MP460 "np paper"
Canon PIXMA MP460 error code 5010
Sep 04, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon pixma mp460 code error 6000
Solutions for error 6000 Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
for the guest
May 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
88 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
