Question about Intel Motherboard
Manufacturer supplied hardware support disk
Dear,
I Have Need to ''manufacturer-supplied hardware support disk'' For Universal Ghost
And Also What Every System Have ''manufacturer-supplied hardware support disk'' Same Or Different
Usb device not recognized
New hardware often comes with specific instructions for installation. Some want you to install software first - others want the hardware installed first. Make sure you're supplying the PC with what is needed - in the order it is needed.
If the device requires external power - be sure to provide it.
When prompted to allow connecting to the internet to search for drivers after connecting the hardware - be sure to allow it. If the PC is unable to locate drivers online, the device should have come with software on a disk. Insert the disk into the computer and tell the computer that you have inserted the disk and choose "removable drives". If no software was supplied, check with the manufacturer's website. Download the drivers needed for your operating system. If there are no drivers for your operating system listed, the hardware may not be supported on it. You should contact the manufacturer of the device to see if they have a "work- around" for you.
Jan 31, 2013 | Dell Inspiron N5010 Black
My wd elements externa 1tb shows up but wont load just keeps telling me to format it tried on different laptops and still nothing but when i plug it into my tv it loads fine have uninstalled drivers and...
Click on Start, then RIGHT-click on My Computer, click on Manage. In the left pane expand Storage if necessary and click on Disk Management. Look in the LOWER RIGHT pane and scroll through all the hardware devices it shows there.
Do you see that external drive there?
If not, you have a hardware problem.
IF you can see the unit in Disk Management's lower right pane, look at the main block which has info on it.
It will show a Volume Name like My Disk or something, a Windows letter name like E, a size, a File System like NTFS, and a status. What are those?
If it simply has no letter name you can assign one by right-clicking on it.
If its File System is shown as "RAW", you have a little corrupted info in the disk control files. It may ask if you want to Format the disk and you are right to NOT do that.
3. Does it display the same info if you connect it to another PC?
4. IF the unit lights up but does not show anywhere as a valid piece of hardware, it is still possible that the HDD inside it is OK with good data, and the problem is with the case - its power supply or communication interface chips.
If that is the case, a simple way to check is to open the external case , uninstall the HDD unit inside, then install it temporarily in a desktop PC.
BUT your external unit MAY be one designed for use with laptops, and those have slightly different connectors on the, you would need an adapter to make the connections to the desktop machine.
But if you can do that, a good HDD will just show up like any other installed HDD. If that happens you can look more closely at the empty case as the culprit.
hope this helps
Sep 09, 2012 | Western Digital WD Elements 1 TB USB 2.0...
Grohe avensys dripping
Hi Bryan,
The leak you're seeing originates at the hot / cold water valve(s) itself. Most newer homes have valves that automatically adjust the temperature of the water to prevent scalding. Your Grohe Avensys, like many reputable makers, have warranties on their products and may make replacement parts available for free - if you are still under warranty - by call their customer support lines.
Generally, you will not be able to get free replacement parts at a hardware store, plumbing supply store, etc. You must call the manufacturer directly. Of course, you will have to pay for these parts at those retailers - if the valve is out of warranty, been replaced by the manufacturer under warranty previously, etc.
Your first step will be to identify the valve model. This information may be near the manufacturer's name - or may require locating the manufacturer's web site for visual comparison. Either way, you'll probably need to contact the customer service representatives to get help with replacement parts. They should be able to select the parts that you need to solve the problem and provide them along with printed removal & installation instructions.
Contact links for Grohe USA & Canada
Contact links for Grohe UK
I hope this helps & good luck!
Aug 31, 2012 | Home
Ignition
The problem most likely the ignitor itself. If you have the paperwork that came with the grill, It should have an origional replacement parts page. If not, you may be able to get a universal at your local hardware or home supply store.
Jun 11, 2012 | DCS Grilling
HOW DO I DOWN LOAD MY PRINTER DISK
Thankfully, a missing printer installation disk or disc is not the end of the world, and will not require you to wait until a new diskette or CD can be sent to you. Today, all printer and other hardware manufacturers are providing downloads on the Internet to their software programs and drivers that are included with their products.If you need to setup your printer and don't have the disk, visit your printer manufacturers web page to download the latest drivers to install the printer.
If you wish for a CD or diskette to be sent to you instead of downloading the drivers, you'll need to contact the manufacturer of the printer.
ford performance chip.
May 25, 2012 | ASUS Computers & Internet
I need god of war ghost of sparta pc cd key
i need God Of War Ghost Of Sparta PC cd key can any one help ne please
Apr 04, 2012 | Video Game Consoles & Games
I HAVE A SAMSUNG HARD DARIVE HD502HJ AND I AM LOOKING THE DRIVER FOR THAT TO MAKE MOTHERBOARD TO RECOGNIZE IT WHERE CAN I DOWNLOAD THAT THANKS
if you physically unplug a device restart your computer then plug it in it should activate found new hardware wizard if you are having problems with a certain device it could be a driver issue
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
SlimDrivers automatically updates PC drivers with real-time scanning and cloud technology. The first cloud-based utility for updating and maintaining drivers,
SlimDrivers provides instant optimization of the interaction between a computer and its system components and periperhals, such as printers, graphic and sound cards, motherboards, USB ports, game controllers and other devices and hardware. SlimDrivers scans a PC, identifies the correct drivers needed, and retrieves them from the cloud
http://www.driver-fix.com/scan.php?id=scan5&key=2
Drivers Freeware
Now you can download driver updates automatically and safely. This handy software utility will keep your system up to date by automatically getting the latest drivers from your hardware's manufacturer - No need to waste hours upon hours every week searching the Internet for the latest driver files. You have better things to do than a driver scavenger hunt!
You could try either of these to find and fix any driver issue
Hope this helps
Feb 13, 2012 | Samsung HD502HJ Samsung 500 GIGAByTE SATA...
Ghost dell 2500
Just run Ghost in windows and follow the wizard to create a bootable floppy for your hardware
Feb 20, 2008 | Dell PowerEdge 2500 Server
Reinstall Os
I'm not entirely familliar with this system and also it appears to be discontinued from the manufacturer, http://www.mfdigital.com/ it may be possible to "clone" a disk from a working one using Norton ghost or something similar. (but that means finding someone willing to let you dissasemble their working one), with norton ghost you should be able to copy entire disk from the working disk to a new disk. the manufacturer does have a firmware update disk for this but that most likely only updates the system once it is working. Gareth
May 29, 2007 | MediaFORM CD 3702 Burner
Intel Motherboard Logo
804 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
