Question about Avaya 5400 Series 5410 Phone
5410 i want to change the name shown on the screen. how do i do this?
You will need to login to Manager and change it, that is the only way.
Posted on Oct 21, 2009
How to change the Extension Name??
If this is on an IP 500, then you will need to access manager and change teh user name.
Dec 11, 2013 | Avaya 5400 Series 5410 Phone
How can i change my nickname on my Fixya profile? thank you
Go to your name at the top of the screen. Go to My Profile. Change Full Name and save.
Oct 04, 2012 | Computers & Internet
Is it possible to get caller ID for an incoming call if I have that number saved as a speed dial? If so, how do I get that. My phone is the Avaya IP Office 5410. Thanks
If the number matches the CID number, you should get the name as well. But here is the hard part.
IF your system requires you to dial an access code (say 9 to get an outside line) you may have that speed dial number saved as:
913125551212
If so, the incoming caller ID would have to match exactly, meaning CID would need to show 913125551212 in order for this to work.
BUT, caller id probably only shows 13125551212, and as such, wont work.
Jul 15, 2011 | Avaya 5400 Series 5410 Phone
Message light on an Avaya 5410 phone will not go off even though there are no messages.
Is that phone an extension of a hunt group? It could be getting messages from the hunt group.
Reboot the voicemail computer, that might reset the light.
Jun 17, 2010 | Avaya 5400 Series 5410 Phone
Hi Expert I have a phone mode is 5410, When I t...
Call a tech. There is a batch file that needs to run and the phone updated....
Pretty advanced IP Office programming
May 20, 2010 | Avaya 5400 Series 5410 Phone
Change main number voicemail
There is no default way to do this. The technician that set the system up will need to tell you the code to get in aand modify that wav file. There is no way to do so by default, it has to be set up, and can be anytihng.
Look at your config, for a short code that goes to a "vociemail collect" with the name recordings.....that is the code you use to modify.
Dec 24, 2009 | Avaya 5400 Series 5410 Phone
Switch board phone needed to transfer lines, etc.?
You should not need the main phone to access the system and make changes as long as the phone you are trying to make changes from has a LCD screen.
May 29, 2009 | Avaya 5400 Series 5410 Phone
Lexmark 5400 series
Problem: Lexmark cannot retrieve applications list
I have the Lexmark X3550 with the WiFi option board installed (makes it same as the model X4550) and get the “cannot retrieve applications list” message on one of the five computers connected to my router (Linlsys WRT54G V8) and using wireless printing and scanning. Just like everyone else with a similar Lexmark WiFi printer/scanner, I can print wireless, but cannot get the wireless scanner to work on one of my PCs.
The fix, in my case, was to change the Lexmark network name as follows.
1. Launch Lexmark Imaging Studio.
2. Right-Click on “View or change network settings”.
3. Enter a new network name in the first box shown. (This box contained the correct network name for my PC, but another name was needed to make the scanner work. I simply added “-lex” at the end of the current network name.)
4. Right-Click OK. You should return to the Imaging Studio screen.
5. Close the Lexmark Imaging Studio window. (The tray icon should remain at the screen lower right.)
6. On the printer, press the Scan Mode button.
7. On the printer’s display screen, select the Computer Name that you entered for the new network name. Just use the arrow buttons until the exact name is shown.
8. Press the Check button. The display screen should show “Downloading Applications List”. Within about 10 seconds the message should change to “ *Scan to Computer ”. Wireless scanning should now work.
9.. Press the Start Color or Start Black button. “Requesting Scan” will be shown. After a few seconds scanning will start. The process is a bit slow.
10. After a while you may see an empty small Lexmark window onscreen. Later, the Lexmark Imaging Studio will appear onscreen, then change to show many options and features. An image of the scanned item will appear in a Lexmark window. Save and/or edit the image. Another scan can be done by pressing the printer’s Check button again. Be sure the correct computer name is shown on the printer’s display.
That’s it. A new computer name was the solution. Your PC and printer may require a restart (power off) after changing the “computer name”.
Regards, Fbyrd
Mar 12, 2008 | HP PSC 2210 All-In-One InkJet Printer
Avaya 5400 Series 5410 Phone Logo
703 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
