Question about Averatec 5110H Notebook
Where is the modem on this system? -I need to replace it.
  • geeks_comput Jul 01, 2009
    Found it under the keyboard. Took it out rebooted, then turned off and reseated it -now it works. Thanks. I guess I was looking for a picture of the MB, schematics, or someone who knew.
    Thanks for the "in general" answer -but the specific answer for this machine didn't match up. I appreciate your efforts.
    -Cosmo
  • 484 Answers
Generally, the modem is built onto the motherboard. Replacing it will take the correct set of tools, the design plan of electronics on the m-board, or someone who does that for a living.
In other words, this is one of those "don't do this at home" types of modifications.
Posted on Jul 01, 2009
I have a hp compaq nx7400 laptop with an agere systems hda modem.i have a dial tone and when i try to connect to the internet the modem sounds like it is dialing but the dial tone never goes away.is the...
The Agere systems HDA modem is a 56kbps modem typically found on laptops. View it in device manager.
Start->Control Panel->System->Device Manager->Modems
Should be listed there. See if there is an exclamation mark next to it.
Not very expensive or difficult to replace
Aug 14, 2010 | HP Compaq Business Notebook nx7400
Got dynalink V1456VQE modem need to install please help how to
internal modem installing:
1.Switch off the power,and remove the power card from the cpu.
2.Get the cpu separately.
3.unsqrew the sqrews and open the system box
4.you can find the white color slot in the mother board.
5.fix the modem with that slot (Modem Board has the single cutting).it must be fitted with the PCI slot.Slight press down.
6.then ON the system,
Start->all programs->control panel->system
->Hardware->Device Manager
now you can see more items on screen,also you can found the modem which you have installed.
Your new modem is ready to use...
7.If your modem came with cd,then insert the disc in cd/dvd drive .Gently Installed the cd...
8.Then Restart the computer.
External Modem Installing:(We do not need to open the system case)
Type 1:(Using Ethernet Cable)
1.Insert the ethernet cable(RJ 45) in the modem,and connect the other end of the cable to cpu.
2.insert a power adaptor in the modem jack.
3.insert the phone line in modem phone jack.(RJ 10)
4.On the system and Modem.
5.Your new modem is ready to use...
Type 2:(Using USB cable)
1.Insert the USB cable in CPU,and connect other end of the cable to modem .
5.You must install the driver software cd came with your modem
6.Restart the computer
7..Your new modem is ready to use...
Feb 13, 2010 | Dynalink (V1456VQH) Modem
New, second modem won't recognize modem
You probably need to install network adapter driver on your new hard drive.
Go to my computer properties, select "Device Manager" and see if there is a network adapter installed and working.
Dec 27, 2009 | Dell (S423) for Dimension 8100 (3F546)...
Internet connection
Depends on your system, install modem first then the system should ask for drivers. Make sure your dial up modem drivers are appropriate to your operating system. Try the modem in a different slot, some modems are not compatible with some motherboards. If the My Computer/System/Device Manager can't see the modem, you have to try another modem or slot. Then install or Update drivers once the system sees it and will show Properties of it.
Aug 19, 2009 | Compaq (198721-001) Modem
Have problems connecting with my ISP
right click on my computer and got to manage. then there click on the driver u want to update, click on update automatically.
if it not help then visit:
moz-screenshot-3.jpghttp://tinyurl.com/m7ghqz
Jun 15, 2009 | HP Compaq Presario SR2011WM PC Desktop
Need free download for modem 56k
  • check the system - device manager for sound adapter, checks for any markings on the device red x, yellow ? , or !
  • uninstall and re-install the modem driver, or
  • install the modem drivers
  • or else call a local computer hardware techician to reseat the modem or else replace it.
Apr 14, 2009 | Computers & Internet
No pci simple communications controller driver
you will need to install the modem driver please check the model no and the modem that you have on the system, select appropriate os and download the appropriate driver from dell support site. Dell support
If you can figure out which modem is in your system and you haven't ever replaced it please call Dell tech support and provide your system service tag they will be able to help you with this aslo you can check your system configuration on the site itself if you have the service tag ready. check dell system configuration
enter the service tag and check under original system configuration will be listed as MDM
Feb 11, 2009 | Dell Dimension 4550 PC Desktop
My computer says there is no internal modem., I have a e-machine model w3650
Normally, if the operating system no longer detects a modem physically installed in the system, it is likely the modem has failed. If you have had any thunderstorm activity or a power surge recently, there are good odds the modem was taken out by the jolt.
You can try reseating the modem in it's slot (it may have worked loose) and inspect it for burn marks or other damage while there.
If the system is under warranty, contact E-Machine and see if they'll replace it. If not, then buy a new modem, you can find them on line for little $$.
http://www.newegg.com/Product/Product.aspx?Item=N82E16825130010
Sep 22, 2008 | Gateway Computers & Internet
MODEM FRIED, NOW I GET COM1 ERROR WHEN REINSTALLING VIA CD(S)
If it's a separate modem card, replace it.
If it's the built in modem, you'll need replace the mother board.
If you have an extra slot, you might be able to install a cheap add-on modem card which should override the built in. But that's a long shot may not work but worth a try.
Nov 05, 2007 | Gateway 507GR PC Desktop
Averatec 5110H Notebook Logo
37 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
