Question about Nokia 6233 Cellular Phone
I have nokia 5310. i cannot remove my password of memory card because i have forgot it. i have no idea about password.so it cannot be remove so please give me a solution
  • 31 Answers
Copy ur datas in th card to ur pc using th nokia pc suite an format ur memory card by selecting th format option n th memory card option... kindly rate me.... thank you....
Posted on Jul 01, 2009
I have nokia 5310. i cannot remove my password of my memory card wat is the solution of this pls let me known fast.
Posted on Jul 31, 2009
SOURCE: Memory card password remover
i have nokia 5310. i cannot remove my password of memory card because i have forgot it. i have no idea about password.so it cannot be remove so please give me a solution
Posted on Sep 10, 2008
Fixe_You
  • 1800 Answers
SOURCE: i forgot d password of my nokia 5310 memory card
hi
Default code for Nokias is 12345. This will work if you did not change access code.
If you set up your own access code, you can recover the code by connecting to computer or using a file manager. You can download Fileman here.
After installing file manager
check the folder C:Systemmmcstore . Rename file mmcstore.txt and send it to another mobile or to your PC via bluetooth or USB, open it and there you will find the password.
Here is also a reset procedure that works on some Nokia, I do not know if it is good for 5310.
Beware, by using reset below you will delete all data stored in phone memory, even phone numbers if they are stored in phone memory:
Take the SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on.
Keep this two buttons pressed until the reset screen appears.
Wait some time to reset.
Switch phone back on.
By Mr.GINKO plz do rate this post
Posted on Oct 20, 2008
hemu112
  • 46 Answers
dear customer thanx 4 visiting fixya....
u hav problem with unlocking ur memory card,as it was designed with fully protected it shows memory card currupted if u enter wrong code for some time,it cant open without the original code......if u want to use the card then u hav to formatt the memory card in ur phone.....not in pc....if u formatt it in ur pc then it shows memory card curropted in ur phone...so format it in ur phnoe.....enjoy using it
Posted on Dec 21, 2008
my memory card have password...and i dnt remember the password??/ tell me hw i can remove it...??
Posted on Oct 07, 2009
SOURCE: NOkia 5310 SD Memory Card Problem
i have forgotten the password to my SD memory card. FExplorer.sis is not supported in NOKIA 5310. Can any one help for this... plzzz...
Posted on Oct 06, 2010
How to unlock memory card
Try and format your memory card using a nokia phone in its memory card manager,it will work.
Dec 08, 2011 | Nokia 5310 Cellular Phone
I forgot my memory card password .. plz help ??? thnx
you can use the Nokia 5310 for many different storage and entertainment functions. The mobile phone has the ability to save all of your large files (such as pictures) to a memory card instead of using up all of the built-in device storage. You may run into issues with the memory card if it is locked. This can happen if you buy a used card or if you forget the password that you programmed into the card at the time of purchase. You can unlock the card with a default password, or you can delete the option that requires the memory card from requiring a password at all.
Instructions
          Unlock the Memory Card
    1. Power off the Nokia 5310. Put the memory card into the memory card slot on the Nokia and then power on the device.
    2. Click the "Menu" key down from the main screen of the 5310. Select the menu option for "Extras."
    3. Navigate the cursor down to the bottom of the page. Press down on the option for "Memory Card."
    4. Click the "Options" selection that appears as a screen prompt. Move through the options until you reach the "Unlock Memory Card" option. Click the cursor to select the "OK" option.
    5. Manually enter in the unlock password with the 5310 keyboard in the password box. When you cannot remember the password, the generic passcode is "12345" or "1357."
          Delete the Memory Card Password
    1. Power off the Nokia 5310. Put the memory card into the memory card slot on the Nokia and then power on the device.Click the "Menu" button down from the main screen of the 5310. Select the menu option for "Fun & Apps."
    2. Scroll down to the selection for "Gallery" and then press on the "OK" key. Navigate to the "Memory Card" screen selection and then press on "Options." Move through the list until you reach "Memory Card."
    3. Press down on the option for "Delete Password" when the screen pop-up menu loads. Verify that the words "Memory card will unlock now, do you wish to proceed?" appears. Select the option for "Yes" to verify the unlocking.
    4. Navigate to the password box and manually type in the default passcode. When you cannot remember the password, the generic passcode is "12345" or "1357." Select the "OK" key when you are complete to remove any passcode requirements from the 5310.
Dec 08, 2010 | Nokia 5310 Cellular Phone
Nokia 5310 micro SD memory card
If you dont remember the password that you gave it, will be undone only by formatting the memory card and thus loosing all data on it.
Aug 31, 2009 | Nokia 5310 Cellular Phone
My phone memory card is locked, i forgot the password.
HI
You have to choose the simple way to remove the password in your , Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
  • go to the file <memorycard>:/system then find the file "mmc store".and rename the file to "mmcstore.txt" (Hidden file should be made as shown from tools->Folder option->Show hidden files)
  • Now open the file in notepad ,
  • No you will see the password.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 27, 2009 | Nokia 5310 Cellular Phone
I've Nokia 5310, forgot the memory card password, help!
#7328748263373738# resets security code.
Default security code is 12345
Jul 16, 2009 | Nokia 5310 Cellular Phone
Dec 06, 2008 | Nokia 5310 Cellular Phone
Nokia 5310
you can't, unless you re-format the card. This will lose any data that you have stored on it.
If you have got the software for your computer for the phone then you ca right click the memory card from within the software and click on format.
Other to that you can by an adapter for the card to fit into the usb port on your computer,(they are relatively cheap), then go to >My Computer and right click on removable device (the one with your card in), and click on format.
I hope this helps
Nov 11, 2008 | Nokia 5310 Cellular Phone
Micro sd card password unlocking.
To my knowledge unfortunately, there is no way to unlock without the password. The only information I can share is to have it reformatted. If formatting could not be performed likewise (due to password restrictions), pls try using a memory card reader attached to a PC and running HP USB Utility (cp006049.exe).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 10, 2008 | Nokia 5200 Cellular Phone
Feb 19, 2008 | Nokia 6233 Cellular Phone
Nokia 6233 Cellular Phone Logo
294 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
