Question about Heaters
Reddy heater repair part number book
Just wondering were to get book on parts number and repair on all reddy heaters.
Re: reddy heater repair part number book
Where can i find i replacement water resivour for a WB Marvin model 5460 Quarts Heat/Humidifier
Posted on Nov 20, 2008
  • 709 Answers
Hi Heaterman,
All reddy should have a label on the heater with their phone contact information. Isuggest calling them and asking them to send you all documentation on your heater.
Posted on Nov 08, 2007
0 characters
3 Points
Reddy heater keeps shutting down. Old heater over 25 years old. Do not know the product name or number
Read these troubleshootingtips. The older heaters are the best, most reliable, and easiest totroubleshoot.
You state: "Do not knowthe product name or number"
Search the unit thoroughly. All parts do not fit allheaters. You must identify your heater in order to get the correct parts.
Sep 21, 2011 | Reddy Heater RLP100 Portable Forced Air...
I have a Reddy heater 125T and the transistor for the ignition is burned into, i was wondering if it is possible to solder a new transistor to the board, and if so what would be the part number for the...
Yes, I have done it and got transistor from a electroic story. took old one to them and they match it. When soldering it on use very little heat not meld the other solder tracks. Ken'Repair
Jan 22, 2011 | Reddy HEATER RH125T 125,000-BTU...
I need a owners manual for my reddy heater 170t, how can I find one?
I think the actual model number for this is RL170AT
This is a DESA manual but the same exact model except for the name:
Over the years DESA INTERNATIONAL has manufactured kerosene heaters with the following brand names and Reddy Parts stocks parts for them all:
  • dayton%203e218cred.gifReddy
  • Koehring
  • Knipco
  • Amoco
  • John Deere
  • Dayton
  • Queen Bee
  • Co-op
  • and many private label brands
If you ever need parts here is the source:
Thanks for choosing FixYa,
Nov 18, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
Reddy Heater 70 (Kerosene) won't start
In the same temperature range that is giving you trouble, run an ext cord (110v) from a known good household circuit and plug the heater into the cord. If the heater runs OK, then the inverter is your problem.
Jan 05, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy heater r155d look-a-like--uses same motor and pump?
155 heaters use one of 2 motors. Either 097308-06 or 102001-30 (now 102001-33), depending on your model. They do not interchange or swap betewwn heaters. Go to . Look up each number. Your motor will have a part number printed on it. Search that model and see if there is a replacement.
1/2" Rotor = HA3004
Dec 27, 2008 | Reddy R155D Utility Heater
Hard time starting-won't keep running
try this link for the owners maual and other information.
Feb 10, 2008 | Reddy R155D Utility Heater
Reddy heater won't stay on
sounds like a Thermal Cut-off this is a small sensor that detects if the heater has ignited properly, sounds like this sensor has failed and the heater shuts off to prevent from gassing anyone
Nov 02, 2007 | Reddy Heater-30-55,000 BTU Variable
Heaters Logo
346 people viewed this question
Top Heaters Experts
Dan Webster
Dan Webster
Are you a Heater Expert? Answer questions, earn points and help others
