Question about Sony Playstation 3 (PS3) Console
PS3 only boots WITHOUT hdd.
I recently got my hands on a faulty PS3 for nothing and am attempting to repair it, thought I might as well give it a go for nothing.
When I turn it on, all seems to function as normal but there is no picture or sound.
If I take the HDD out and then try to boot, it boots and all is fine but it tells me to insert a hard-drive.
I'm assuming I just need to get a new HDD and pop it in, but has anyone else got any ideas before I spend money?
Cheers
Buy a harddrive off ebay i had the blackout problem with a $200 60g and upgraded it to 80g for $35
Posted on Jul 15, 2009
Asrock G31M-S No Display/Booting
First of all, check if there are any inflated capacitors, if there is even one- ditch MBO, other capacitors will soon follow. If no inflated capacitors proceed with these diagnostic steps: 1/ disconnect all peripherials (DVD, HDD, card reader...), leave only MBO, PSU and RAM (and CPU of course); if nothing happens 2/remove CMOS battery (CR2032) for 20-30 sec with power cord disconected from computer, that will reset BIOS; 3/ take out RAM sticks, then, if you have more than one stick, try with each stick separately (it might be faulty RAM); 4/power on MBO without any RAM-if speaker is present it should give BEEP signals; 5/ try with different PSU, many power supplies are faulty even when they do give power to MBO.
If nothing of above does not help than you have faulty MBO, because CPUs are so rare to fail that in my 10 years of experience in PC service I had 3-4 fried CPU-s, and even that was because costumer tried to clean PC, removed CPU cooler and than incorrectly placed it back or didn't put thermal paste afterwards. asrock-g31m-s-no-display-booting-yuc33qzjuwfqgyyin4u45syc-4-0.jpg
Dec 18, 2014 | Asrock Computers & Internet
My Hp compaq PC showing problem about HDD - Disk Read Error . But This HDD was run very good to another PC ?
Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. b> 1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi... or rather than doing this try the alternative which is windows own repair Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download http://www.RepairErrorInstantly.com/ttfi... Then restart again into safe mode with command prompt. Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer Hope this helps. b>
Jan 05, 2013 | HP Compaq dc7700 PC Desktop
My computer reads' replace disk. Incorect system
Check to see if a CD or DVD has been left in the CD Drive (most PC's attempt to boot from this device firs and if there is a non-bootable disc in it sometimes gives you that message). If there isn't a disc in the drive then you need to check the BIOS boot settings to see if the correct HDD is selected as the boot device. If both of the above are OK then it is possible that the HDD is faulty.
May 26, 2012 | Intel Computers & Internet
I have a dell demension 531 w/ vista home os. On boot up "Error loading operating system" appears. Have restore disk but don't want to lose data. Can os be restored without losing data
#1 boot to the F12 menu and run diagnostics and see if the HDD has a failure.
If it doesn't have a HDD failure code, then boot to your Vista recovery DVD and run a repair (This will not cause data loss) if you run repair (you may have to do more than one [Attempt reboot between attempts] until it give a message that there is nothing it can repair) and see if you can get back into windows
Jan 15, 2011 | Computers & Internet
I have a 40gb old hdd. it was a currapted .i install the hdd in other pc then i boot from bios setup. but hdd is not booting. the error is display -the disk is not bootable... how i boot the harddisk now....
If the drive is corrupt in one PC it will still be corrupt in another.
There are apps for recovery and attempted repair of HDD's but you have to weigh off the cost of the apps against cost of neww HDD.
Aug 27, 2010 | Online Computers & Internet
Drive not accessible due to I/O error
Without a windows cd or recovery it is very hard. You should take some cd from somebody. At other hand, you can connect your hd to another pc and try program - hdd regenerator- on it.
Apr 10, 2009 | Sony VAIO VGN-NR110E/W 15.4-inch Laptop...
Working but no picture or sound
power of the ps3,remove the hdd.turn on the ps3 without the hdd.picture should come in about 1 to 2 minutes.return back the hdd,hope i helped you
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
PS3 60GB
Try removing the HDD via the little door on the left side of your PS3? Try an boot without the HDD then see what happens? I am up to my second HDD after my first one caused similar problems (60GB model). I hope that this helps?
Nov 13, 2008 | Sony PlayStation® 3 (60 GB) Console
Sony Playstation 3 (PS3) Console Logo
231 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
