The speakers work fine but with the volume at max all you hear is a whisper of noise? is there a wiring diagram i could have to see about the connection of the audio to the motherboard?
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
yes i have
tried that to still have a problem
have you tried going to the little speaker next to your clock and turning it up there?
