Question about Migali Imperial RF82AT Stainless Steel
Migali f82at-------Only 30 volts are at the evaporator fan motor connections.... also the condensate pan heater burned up, would the fact that its (pan heater) not hooked up have anything to do with the fact that the fans are not working and the fact that the voltage is so low.... also is there supposed to be a thermal switch to activate the fans???
Does a bosch fridge freezer always have water in the evaporation tray?
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
It is normal to have water in your evaporator drain pan.
Your refrigerator goes through a defrost cycle every 8-10 hours, where your refrigerator will shut down for about 20 minutes and your defrost heater turns on.
You do not need to clean your drain pan. You have a condenser fan that blows across the drain pan to evaporate the condensate.
You drain pan will fill during the defrost cycles. the condenser fan blow across the drain pan and will evaporate the water.
The amount of water in your drain pan will depend on conditions such as high frost in the freezer.
Mary, you had just happened up the drain pan not completely evaporating the condensate.
Sounds to me like you are in good shape.
Peter, Baltimore, MD, USA
Nov 02, 2014 | Bosch KAN60A45G Inox 510 l Fridge Freezer...
My 2004 rodeo ac/heater fan is not working. once in a while it will. i need to know where to search for my fan and/or connections. Plus in summer my condensation leaks in the passenger side of truck. Need...
Replace fan motor and resistor at the same time to fix it. A bad fan motor will burn out a resistor. Clean drain tube at bottom of evaporator case
Jan 02, 2011 | 2004 Isuzu Rodeo
Both sides of the refriderator is not freezing or cooling
hello,
Insufficient cooling is a fridge repair job that you can do without the help of a professional. Often the fridge has a frost-free failure, or the compressor is faulty but there are many other reasons for a fridge not cooling properly. Step 1 - Find the Problem
Your first job is to locate the source of the problem. Consider each of the following:
* Gaskets - Make sure the gaskets/seals are not torn and are sealing properly. * Evaporator fan - Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches). * Air damper - Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section. * Condenser coils - Check to see that the condenser coils don't have a dust build-up and that the condenser motor is working. * Compressor - Make sure your compressor is working with on and off clicking noises.
Step 2 - Frost-Free Failure
This is the most common cooling problem in fridges. Expose the evaporator coils by accessing the panel in the freezer section. The coils in the freezer section can sometimes get clogged up with frost. This can stop the evaporator fan motor from blowing cold air around, or cause the fan to hit it and stop, or become noisy. The defrost timer can be a bit tricky to find but it is usually located behind the back bottom corners of the fridge, although they can sometimes be found in the ceiling of the fresh food section, or behind the cold control cover. Step 3 - Find the Timer
When you find the timer, turn the wheel-like screw slowly with a screwdriver until the fridge shuts off. The refrigerator is now defrosting. If you find that the fridge starts now, you will need to replace the defrost thermostat and the defrost timer. Step 4 - Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven't got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
If there is a ticking or squealing noise in the defrost timer, or it seems hot to touch, replace it.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn't work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils,
I hope this work fine...Take care.....
Oct 31, 2010 | LG LRSC-26922 Side by Side Refrigerator
Not cooling
Step 1 – Find the Problem
* Evaporator fan – Make sure it is working. If it is now working you may have a problem with the fan motor. Check for power to the motor and also examine the fan switches around the door (not all fridges have these switches).
* Air damper – Sometimes the air damper will not open up to allow the cold air from the freezer part to blow into the fridge section.
* Condenser coils – Check to see that the condenser coils don’t have a dust build-up and that the condenser motor is working.
* Compressor – Make sure your compressor is working with on and off clicking noises.
Step 2 – Frost-Free Failure
Step 3 – Find the Timer
Step 4 – Volt Test
If the heaters do not come on, use a volt meter to ohm test the defrost heater or volt test for 120 volts to the heater. You can bypass the defrost thermostat if you haven’t got power to the defrost heater to check if the defrost heater will come on. To bypass the thermostat, join the two wires together. Replace the defrost thermostat and the defrost timer if the heater comes on now.
Many fridges have and inline fuse on both sides of the defrost heater. You will need to replace the whole heater if one of those fuses blows. Check these fuses with a volt meter if the defrost heater doesn’t work.
A quick check if you have a cooling problem is to inspect the evaporator coils. If there is a build up of white snow on the coils, this indicates a frost free problem; if there is balled ice on part of the coils with the rest bare, this indicates a system problem, like a problem with the pumping compressor.
Take care......
Aug 14, 2010 | Kenmore Refrigerators
Fan turns on then off refridge not cooling
Step 4 – Volt Test
Take care.....
Aug 10, 2010 | Marvel 6BAR-BD Beverage Cooler
Not gettin cold
Step 4 – Volt Test
Hope this helpout.....
Aug 09, 2010 | Frigidaire Refrigerators
Electric panel is not lit, not keeping food cold.
Step 4 – Volt Test
Good luck.......
Jul 28, 2010 | Samsung Refrigerators
My Fridge is warm, but my freezer is working great
Step 4 – Volt Test
hope this help.....
Jul 28, 2010 | Maytag Refrigerators
Freezer is cold, ice maker not making ice and refrig. part not cooling.
Step 4 – Volt Test
Hope this helpout
Jul 28, 2010 | Frigidaire FRT17G4B Top Freezer...
Samsung AW1003M Air Conditioner how to clean Fan inside??
hello! there well, there are two fan coupled together on a/c the condenser fan and blower fan,if this is split type the fan and blower are separated.the procedure is the same way.doing this release lock off and take off front cover then pull out ac unit assembly,after pull out,open terminal control box disconnected all wiring connected on compressor motor and fan motor, loosen all stud bolt on compressor blower fan case.this well exposed fan and blower w/ the motor.cover the motor of plastic sheet then, pressurize water wiil use to clean blower fan observed the motor not to wet by water if this wet don't try to run let it dry off or else this wii burn out so take all necessary precaution, beside mosly cleaning procedure includes the fin tube of condenser and evaporator there are foriegn particles and moisture emerged in evaporator mostly that why insufficient cooling effect on condenser heat rejection also affected if dirty fin tube emerged,.theres is lye detergent use and mix to water pour this to evaporator and condenser fin tube wait for 15 to 30 min soaking to rinse dirt will come out to fin.observed not to distorted fin of tube on eveaporator and condenser.,then pressurise this by water again if cleaning was done dry it off until all dirt disappear.if finishe put back all casing of compressor,evaporator and condenser, then connect all electrical control connection on circuit board, double check connection just put back what ever disconnected parts dont try to alter specially electrical control connection on circuit board.this is a hard task and risky if yout not qualified to handle this job bring it or call a service technician.have a nice and cool day regards and thank's.
Mar 29, 2009 | Samsung AW1003M Air Conditioner
Migali Imperial RF82AT Stainless Steel Logo
Top Migali Refrigerators Experts
Ilia Bichin
ray gallant
Tom Chichester
Are you a Migali Refrigerator Expert? Answer questions, earn points and help others
