Hello, if the key is broken (Won't work at all) there is no way to fix it unless you replace the keyboard. You can however look for the: ATK / KB Filter Utility for Asus machines and that will give you access to some of the hotkey functions without having to use the fn key itself. You can find that here: http://support.asus.com/Download.aspx?SLanguage=en&m=ATK_package&os=30
Unfortunately the fn key is not part of standard bios's as far as I know for most machines so you can't remap it to another key. You might be able to switch the [fn] function around though so you don't have to press the [fn] key to use the hotkeys.
It will look something like this: http://cdn4.thetechjournal.net/wp-content/uploads/2012/10/action-keys-bios-as7d889we79we7r9ew5rty321u32.jpg
To get there hold [F2] whilst powering on the machine and you should see something similar to that pic. Once done save and exit.
Please bare in mind that if you do this you will only be able to us the hotkeys in windows unless it's a keyboard specific command, e.g [Ctrl] + [Shift] + [F4].
Hope that helps
Hello there, the specific driver you're looking for is this one:https://esupport.sony.com/US/p/swu-downl...
The drivers you're looking for are all located here:https://esupport.sony.com/US/p/model-hom...
SOURCE: function key doesn`t work with windows 7 installed
My Vaio model is VGN-FS840 and after I formatted by laptop, my function key is not working, what shall I do to make it run? Can I download the driver? is it available in websites?
