Question about Acer Aspire M1641-U1521A PC Desktop
Windows explorer non responsive when sd card inserted. Computer runs slow when using Serif PhotoPlus 9 or 10 and eventually becomes non responsive.
    President:
  • 1,462 Answers
Hi p_allchin1,
This probelm usually occurs when there is problem with the card reader device or even due to faulty cable between the card reader and the System, try replacing the wire and if *** fails replace the reader....
There is a chance of this problem occuring due to Faulty card also..
Ebjoy!
RNJ VINOD KUMAR
Posted on Jul 01, 2009
Mu computer is windows 7 professional
Marie, If your computer is not equipped with a SD/Micro SD card Reader you will have to purchase one to simplify looking at it and copying it on computer. You can also use appropriate cable possibly to hook your camera up to computer.
Step 1/ Insert a USB card reader into an available USB port on your PC.
Step 2/ Insert the micro SD card into the card reader. Some card readers will only accept standard SD cards. If that's the case, insert your micro SD card into an SD card adapter and insert the adapter into the card reader.
Step 3/ Click "Open Folder to View Files" in the Auto Play window to launch Windows Explorer in the appropriate drive letter. Alternatively, press "Windows-E" and click the card reader's drive letter.
Step 4/ Drag and drop files to or from the micro SD card's drive letter to copy files. Alternatively, right-click and drag files and then select "Move Here" to move the files without keeping the files in the original location.
Step 5/ Select a file, press "Delete" and select "Yes" to delete files from the micro SD Card.
Step 6/ Right-click the micro SD card's drive letter and select "Eject." Once ejected, you may safely remove the card.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Transfer Pictures From MicroSD Card to PC
How to use card reader
Card Readers Adapters
Memory Card Readers
Aug 20, 2016 | Cameras
My TransFlash 2.0 memory card doesn't show on my lap top
First, the basics...
There are three kinds of SD cards (SD, SDHC and SDXC). Not all computers are designed to accept all three types. SD cards can store up to 2GB of data, SDHC can store up to 64GB of data, and SDXC cards can store up to 2TB (terabytes) of data. If you are unsure which types of cards your laptop or computer will accept, visit the manufacturer's web site and look for the specifications for your particular model to be sure. It's tempting to want to buy an SD card with a large data capacity, but it's wasted money if your computer will not work with the high capacity card.
Make sure you have inserted the card correctly (and fully). The card is 'keyed' (with a notch in one corner) so it should only fit into the SD card slot one way *easily*. Obviously you can try to force the SD card into the slot the wrong way, but the position which goes in the easiest is probably the right way. Some devices have a symbol beside the slot indicating which way the card should be inserted. Be careful, though. It is natural to think the the card should be inserted with the manufacturer's label facing up, but I've seen devices where the card should be inserted 'upside-down', contrary to what I thought.
If you are using a Windows computer with a 'recent' version of the operating system (Windows Vista or later), the computer should recognize the card (as a newly attached piece of hardware) and show the card as a new drive letter when you open the Windows Explorer program to view your files and folders.
If the card is new, it should be formatted already and can be used immediately, BUT...your computer may need to have a driver program (software that enables the use of specific hardware items). My laptop, for example, uses a driver from Ricoh to enable the SD card slots, and that driver had to be downloaded from the HP support site and installed before my SD card slots would recognize SD cards.
If you know you have the correct SD card device driver installed, have an SD card that will work with your computer but still do not see the card in Windows Explorer, you can check in the Windows Device Manager to check its status. You can also use the Disk Management features of Windows to check what drive letter has been assigned to the drive. If the SD card has been assigned a drive letter already used by another drive, then it will not be available in Windows Explorer.
If you think any of these last problems I mentioned are part of your issue, reply here and I can see if I can help you further.
Apr 18, 2016 | Kingston Electronics - Others
Need a key for serif photoplus
Please purchase the product and support its developers in order to obtain a valid serial key.
Dec 16, 2012 | Serif PhotoPlus X3 Digital Studio
How do I copy pictures etc.to an SD card on an Acer Travelmate 3270 ?
You would use a file explorer program like Windows Explorer in Windows operating system.
Aug 21, 2012 | Acer TravelMate 3270-6569 Notebook
Just purchased your photoplus x4, and cannot install it. Im using a Dell dimensions 1100, with XP, and service pack 3, which supports UDF and PDF file formats. All of my drivers are current and up todate....
The Latest version of this software is X8. Are you using 4 because you have XP. You should really upgrade to Win 8 or 10 to get the support and AV cover from M$.
However, I have two suggestions.
1 is to use compatibility mode
2 is try and load it in Safe Mode
Make sure you have AV turned of if you have any.
Finally, you realize we are Fixya, a self help website, and nothing to do with Serif and this software. You wrote "I purchased YOUR photoplus". Here is the forums for Serif and the software. For some reason, they provide no support themselves.
https://community.serif.com/
Mar 08, 2017 | Serif Photoplus X4
Order No E81847770 No SSE2 on my Computer Processor Need non SSE2
And now you have given anyone who wants it your account number and email address.
You need to talk with Serif
Jul 29, 2010 | Serif PhotoPlus X2 Digital Studio
Acer Aspire M1641-U1521A  PC Desktop Logo
111 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
