Question about Vizio GV42L 42 in. LCD Television
Screen turns green after 20 minutes of use
Have a small static line at top of TV. Screen begins to get green blotches in it once TV has been on for 20 minutes or so. TV is brand new
    Problem Solver:
  • 10 Answers
Static line at top is a problem with the broadcast input. many cable boxes and satellites create this because they dont quite fill the true resolution that the tv is capable of. the green splotches sound like overheating of the lcd lamps. id return it for a new one.
Posted on Aug 10, 2009
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
How do I get small green things off the screen. Brand new TV.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 28, 2014 | Televison & Video
I have a 2 year old LG LCD TV (model 42LG60) and I am having problems with the screen. I turn it on and everything is fine for a few minutes and then the screen goes to red or green lines that are fuzzy....
Not really a solution, sorry, but I've got the very same problem. I haven't noticed the time before tv faults, but nontheless, it greenscreens or like in your case, redscreens as well. I've been told to open the back, which I did to check the status of the capicitors, which I've done. But, the capacitors "seem" fine. No bulging or popped tops. So, I'm at a stand still...not sure what to do at this point. If someone gives you solution, I sure would appreciate your forwarding it on to me. Thanks. Robert
Oct 23, 2011 | LG Scarlet 42LG6000 42 in. HD-Ready LCD TV
Flickering screen and lining-out on top inch at first
This sounds like tiling. are you using a cable box?
May 07, 2010 | Vizio GV42L 42 in. LCD Television
Static noise and blurry screen
You need to take your TV set to Service Center, because the inner parts, especially the flyback transformer, been damaged or worse, the connector broken, that's why you can hear the noise.
Mar 07, 2010 | Symphonic ST420FF 20" TV
My kid ran a magnet across the screen now there's a purple blotch along the top of the screen.
The TV needs to be degaussed.
There is an automatic degausser built in but it may NOT be strong enough.
Try this: Turn off the TV and let cool for 10 minutes. Then turn on for one minute.
Repeat the previous sequence until screen is clear of blotches.
The cooling period re-arms the degausing circuit.
If this doesn't fix it adequately, you need to find a TV repairman that has a degausing coil... these are getting a bit rare now. It would take him ten minutes with the coil to fix it.
Dec 25, 2009 | Sanyo AVM-2506 TV
Green blotches on screen
your vs and va need to be adjusted on power supply i can walk you through it but requirs volt meter and taking the back panel off tv
Jan 15, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Could my laptop screen be leaking?
Sounds like the LCD has sustained physical damage. Replacement is the normal solution.
Monitor Mike
Jan 02, 2009 | Apple Cinema 20" LCD Monitor
Grey static then flashing button
Could be your flyback transformer or these caps 2200 mf16v 22035v 33035v. Check the caps for bulging.
Jul 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Vizio GV42L 42 in. LCD Television Logo
417 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
