Question about Honda Pressure Washer PSI 3000
Electric simoniz runs for a while than cuts off for awhile and st
Simonize 1900
  • 174 Answers
Hello: Are you using and extension cord? You cannot, it will kill the motor. If this is not the problem it is the unloader valve sticking. This is quite a job to fix but can be done. Let me know.
Posted on Jul 01, 2009
Simoniz wand
Pressure washer use special ORINGS not the round ones and a high pressure stream of water will cut skin! Did you purchase the oring from a simonize dealer or a box store?
Apr 04, 2014 | Garden
Gilera runner 125 st 2008 cuts out by arcing
coil lead plug cap needs replacing , no shield to protect spark plug from getting wet due to weather/water splash. electrical spray lubricant requires from damp start problem
Dec 29, 2012 | 2008 Gilera Runner ST 125
Gun leaking when i use my simoniz 1900 pressure washer
The simoniz 1900 gun is very poorly designed. It is held together by a dozen small screws.
First open the gun by taking all the small screws out. No worries, it is much more simpler and worse constructed than a 5-year-old toy gun.
After opening the gun, you will see there are only two parts inside. One at the front connecting to the wand, and one at the back connecting to the hose. The trigger is looped over the joint part.
Make sure the back part is firmly fitted into the slot properly, otherwise it leaks. And be careful don't lose the spring, because there is no object to hold it in place.
Now all you need to do is to put all one dozen small screws back in. Don't over tight the screws, otherwise they will punch through the plastic cover.
Now your simoniz 1900 gun is fixed but it leaves you wonder which 10-year-old designed it?
Jul 30, 2012 | Honda Water Pump 2 Inch IntakeOutlet 5 Hp...
I would like to take apart my Simoniz pressure Washer
I have simoniz 1750 less than 2 years old it works,no leaks,but water is not coming out ,thank you for any tip.
Mar 31, 2010 | Garden
Where is the pressure switch located on a simoniz 1600 electric power washer?
There is a pressure switch to cut the motor once target pressure is reached. I.e. when the nozzle is closed. It's a black cheap plastic thing, right in front of the pump body. It has a white plastic lever to trip the switch. It was sticking intermittently on mine. the simoniz 1600 is quite a cheap peace of ****, needs fiddling around every time I use it
Sep 16, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
S1600 Simoniz gun - I took it apart and I have a spring left - where does it go? I need a schematic or something.
There are no schematics available because the manufacturer doesn't sell parts for the gun. The spring usually goes right into the end of the hose, then the little bullet like valve follows. Did you know you can buy a new gun for about $22.00 Canadian?
Aug 11, 2009 | Karcher Garden
I have a Simoniz 1900 presure washer and had to take it apart to fix it. I need to know how to put it together again as it has been awhile since I have had a chance to work on it. Can anyone tell me how to...
i took my pressurewasher simoniz s1900 apart, i had to take off the pump and all oil leaked out.
how and where can i fill the oil in to the pump
and what type of oil would i use
thanx ernte
May 17, 2009 | Garden
Simoniz s1900 electric power washer with no water pressure
What a jacka$$ response.
Do you think its the seals? wow that describes f**Kall!!!
Aug 19, 2008 | Electrical Supplies
Honda Pressure Washer PSI 3000 Logo
729 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
