Question about Fisher and Paykel GWL11 Top Load Washer
GWL11 will not come on.
The washer went off after completing a load cycle and now will not come back on. There is power at the wall. I have left it unplugged for several minutes but nothing has changed.
  • 1 more comment
  • msummitt Jul 01, 2009
    Before it stopped, it finished a complete cycle. There were no problems with drainage at all.
    There didn't seem to be a problem with drainage when the last cycle ran.
  • msummitt Jul 02, 2009
    Yes, very helpful. It's going to save a couple of $100 bills.
  • 15,935 Answers
The timer on your machine has failed. Unfortunately it cannot be replaced as an individual component. The entire controller must be swapped out.
The controller # is 420094USP
CLICK HERE to see the Exploded Diagram... #6
and CLICK HERE to order a replacement board.
Thanks for using FixYa!!
Posted on Jul 01, 2009
    Brigadier General:
  • 3,917 Answers
Sounds like it's not detecting an error. This would indicate a blockage in the drain pump or outlet. Check these for blockages and try the machine again.
Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
Thanks for contacting Fixya
My washing machine does not complete full cycle it washes and then shuts down at rinse cycle. When advanced over first issue it will complete the cycle.
Your problem is going to get worse, really soon. The DC motor on the bottom of the washer needs to be replaced. The windings inside the motor have shorted together and cause it to draw too much power, shutting down the washer. The motor is expensive, home warranty covered mine.
Oct 08, 2010 | Fisher and Paykel GWL11 Top Load Washer
Our fisher paykle washer would not complete the spin cycle yesterday, my husband got it to finish the load yesterday and now when I went to start a load tonight the power button will not work. We checked...
Hi just found your posting.Do you still require assistance?The problem with your machine if you 100% have power to it is either your drain pump is faulty or your control module is faulty.Please reply and I can help you further if needed.Hope this helps.
Jun 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Squealing sound on spin cycle.........
Turn power off AT THE WALL,under the wash bowl Spray some wd40 on to the pump at both ends, while this may stop it for a while. Your pump may well be on its way out. you should replace for a new one. bad pumps can cause more problems problems .
Mar 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
Slow running washer
The beeping may be a code to tell you what the problem is, ie low water supply, overloaded, out of balance, etc. My user manual has a problem-solving page that explains the different beep sequences.
Jul 25, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
F&P GWL11 will not power on...
You might try: http://usa.fisherpaykel.com/global/customer-care/trouble-shooting/washing-machines.cfm?CFID=5795181&CFTOKEN=46306735
Dec 12, 2006 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
61 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
