Magnavox 42mf231D/37, no video, audio only. No menu, no snow, no picture at all . . . black screen. Just audio is fine.
  • waysmart Jul 01, 2009
    okay, banging does not work. I'm fairly techincal, with computers, not TV's or monitors. Is this a board swap, or soldering a new something or another onto the circuit board? I know what capcitors, diodes, resistors, coils, ic's, etc. look like so I could potentially find something like that if I knew what to look for.
  • 3,230 Answers
When the screen is black (no raster) it means you have lost the high voltage that
feeds the picture tube. High voltage comes from the flyback transformer which is
part of the horizontal deflection system.
Therefore, the problem could be a bad flyback, bad horizontal output circuit or
any other part of the horizontal driving system.
The cost of repair is generally quite expensive and if the set if over 4 or 5 years
of age you may want to think about just replacing the set. If the set is quite new
it certainly is worth the money to repair it.
It is not a repair that can be made at home unless: a) you are a qualified tv technician,
b) you can bang on the set and find that it is being caused by an intermittent that
comes and goes (let me know if so and I will tell you how to proceed) or c) you
are extremely adventurous and want to do it to learn about the process of troubleshooting
and diagnosis of television receivers.
Good Luck!!
Thanks
Posted on Jul 01, 2009
  • Mukesh Kumar Jul 01, 2009
    It need only soldering not replacement, it need some capcitors, diodes to solder on board.
My Magnavox 42MF231D/37 TV has no picture
Call Magna vox tech support. Sounds like you need a new set. They may have you factory reset the set.
Feb 20, 2015 | Magnavox Televison & Video
I HAVE 42 INCH MAGNAVOX PLASMA TV AND THE SOUND WORKS BUT THE TV DOES NOT SHOW A PICTURE AT ALL IT IS JUST ALL BLACK,COULD IT BE THE PICTURE TUBE THAT WENT OUT.
yes...the video card could have gone out but most likely you have a connection that is loose or bad. I would check those first. If you have done so then I would try another video port and verify that it is the screen that is out and not just the port you are in.
Oct 11, 2013 | SNK Magnavox 42MF231D 42 in. Plasma TV
42'' Magnavox 42MF231D/17 with picture/sound problem
Hi my name is Roety,
I can help you with your issue ,
Sounds like a bad SSB small signal board
login as a guest and check price and availability at
encompass.com
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 31, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox 42MF231D/37 screen went white then black
Alot of times i have noticed that when i have worked on these, it has been the Backlight Inverter. 32 inch televisions had same problem as the 42 inch
Oct 18, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Magnavox 42MF231D/17, screen just turned black,
power supply or inverter board failing if the power board is the problem it will have blown caps
little cans with puffy tops because the caps have vented if you don't see that then your inverter has died that model id out of production so try shop jimmy. com
Sep 22, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Magnavox 42mf231d/37 - no picture
Common problem on this tv, ceramic capacitor beside horizontal transistor.Need be Replace . 561K 2KV
Aug 06, 2009 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
