Question about GE JGBP28 Gas Kitchen Range
Ovan and broiler arn't turning on. Makes a click
Ovan and broiler arn't turning on. Makes a click sound to turn on, but it never turns on
  • 64 Answers
Bad clock
Posted on Jul 01, 2009
Light, oven, & broiler not working. Oven & broiler just makes clicking sounds. replaced control panel twice.
sounds like a burnt out element to me . have someone watch inside the oven when you try turning it on they might see a spark letting you know what area to look in .
Apr 27, 2015 | GE JBS55DMWW Electric Ranges
Last week when my wife turned on the oven a flash and popping noise happened and the circuit breaker popped. I ordered a new control board part number WB27T10229 and installed it. When I turn the circuit...
The broiler is a different element. Sounds like your main (bottom) element is out. Turn off breaker and remove. To test, use an ohm meter and ohm out the element. If yuor meter reads 0 or OL (open load) your element needs to be replaced.
May 19, 2011 | Kenmore 95882 / 95884 / 95889 Electric...
Top ovan will not start when I put ovan on the blower does not wo
the problem is not the motor. You have a problem with the door switch or the operator interface.
May 04, 2010 | Bosch HBL 455 Stainless Steel Electric...
My stove works and so does my broiler. I replaced
If you use a multimeter, you can test the gas valve where the white and yellow wires connect is where your terminals for bake on that valve are. If you have continuity there, then check to make sure that igniter is wired ok.
http://tclaundryrepair.com/home
Feb 19, 2009 | Whirlpool SB160PEE Gas Single Oven
Broiler has gas burning problem
clean all the broiler burner ring holes with toothpicks then clean the burner ring with dishwashing soap and, rinse with clear water. wait until dry then: try the broiler again; sometimes the holes the gas comes out of gets plugged with grease and the burner ring/rod makes a whoshing sound when the excess gas pressure builds up and the gas escapes the burner ring all at once then the cycle begins again
Nov 29, 2008 | KitchenAid KGRT607 Gas Kitchen Range
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
Wont' heat in broil or bake
check incoming electric first, pull it out and gain access to main wire terminal, With multimeter set to at least 250v AC , check your power across the wiring as such. black to white (110v), red to white(110v) and then black to red 230v. if that ok ok turn, then start ckin elements for continuty also there might be a thermostat( usually an 1 in. round component with 2 wires located right inbetween the elements that has gone bad, will show no continuity. ck that before electronic control the fact that its clickin sounds like the relays are workin properly
Feb 23, 2008 | Ovens
GE JGBP28 Gas Kitchen Range Logo
148 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
