Hp Compaq 6730s. Just installed 2 sticks of new RAM (2GB each) but the screen won't come on. Switched each with original 1 GB stick and tried them both solo - still doesn't work.
Only the original RAM is working.
Please help.
Comments:
Jul 01, 2009
- The RAM is 800 Mhz. Confirmed that it was the correct RAM with the HP website before ordering and after receiving.
did you check the type of RAM you are inserting maybe the RAM is not compatible a ram has many specifications including the frquency at which it works
so check if you got the right ram for the laptop the frequncy is something like 533, 800 Mhz so see the one you had originally and get the one required for the laptop
Comments:
Jul 01, 2009
- did you check the type of RAM you are inserting maybe the RAM is not compatible a ram has many specifications including the frquency at which it works
Jul 04, 2009
- then there might be a problem with the ram you have received as there may not be any problem in the way you are inserting the ram as the original ones are working
but still try this thing may be there might be a setting in the bios for the change in rom i do not know wheter there is one or not but try to enter your bios and try to put it to default & safe mode and then reboot
Was this helpful?
Yes
No
Popular Solutions for HP Compaq nx6310 PC Notebook
i have a laptop hp compaq nx7300 and i have change the AC power adnd now he didn't found hin...
(More)
i have a laptop hp compaq nx7300 and i have change the AC power adnd now he didn't found hin battery.can replace on linuradu@yahoo.com
I just put a new battery in my laptop and it still does not turn on. what do i do? my laptop is a...
(More)
I just put a new battery in my laptop and it still does not turn on. what do i do? my laptop is a compaqnx6310
