Question about Refrigerators
Whirlpool top freezer mod#et1ftkxkq00 which when frezer gose into evaporation mode water drips threw square insets into refrig. compartment,a friend has same problem.What do i do to correct this? I was told to defrost entirely to melt ice blockage to drain to bottom tray.
  • Tony Houde
    Tony Houde May 11, 2010
    you look in the freezer what do you see when you look at the freezer floor??
    President:
  • 1,136 Answers
HI, Unplug the refrigerator. First thing you do is remove the floor panel of the freezer. Do you see ice?
If there is ice, remove the rear wall of the freezer as well and start removing the ice. There will be down inside the drain hole also. A hair dryer works great for this project.
Please do not use sharp object/tools.
Now that you have the ice out of the drain, There is an after market drain transfer heat strip kit you need to buy and add. Part# 819043
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jul 01, 2009
  • 1 more comment
  • hzglauren Feb 17, 2011
    I have the same problem. When I looked up that part number on the Whirlpool website, I couldn't find the part. Does it still exist?
  • patman2 Mar 18, 2011
    I had this problem also. See my post:http://forum.appliancepartspros.com/refr...
    Why does this happen in the first place? My previous Whirlpool top-mount ran for 30 years without its drain hole ever getting blocked or its tube freezing. Whirlpool claims no knowledge of people having this problem but there are numerous similar posts on the web.
1992 T&B refrig drips water from inside top of refrig compartment Is it a blocked drain tube? Or bad heater evaporator unit?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Amana ATB2135HR Top Freezer Refrigerator
Water dripping into fridge
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
May 28, 2010 | Frigidaire FRT21H8 Top Freezer...
FREEZER COMPARTMENT FREEZES AND WATER RUNS INTO REFRIG.
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Apr 09, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dripping in the refrigerator and freezes on the top shelf. It seems to be coming from the freezer compartment. There is a square piece of metal missing from the top of the main compartment. One can...
Removed everything from the freezes. Removed a false bottom from the freezer floor, 2 screws. There was an ice build up under this plastic bottom. I let the ice melt with the de-frost cycle (or frost free cycle). No more water dripping into the refrigerator compartment.
Dec 15, 2009 | Whirlpool Refrigerators
Kenmore Cold spot refrigerator model 106 70182001 leaking inside in the back of the refrigerator. Having to keep bowls in the back of the top shelf. How can I fix this?
Your defrost drain in the frezer is cloged. Every day when your refrig sellf defrosts the water should drain into a hole that leads to a tube wich drains the water to a pan under the refrig. You need to turn offrefrig and remove frezer floor and rear wall and clean out hole and tube with hot water.
Dec 12, 2009 | Cars & Trucks
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Fridge leaks water on the inside, is not condensation
Hi!!! Your drain line is plugg, also there might be some dirt plugged so remove the evaporator panel are clean the drain line..deb5a30.jpg
Jan 04, 2009 | Whirlpool ET1FTKXK Top Freezer...
WATER DRIPPING FROM TOP OF REFRIGS MAIN COMPARTMENT
The drain is clogged.
This water should be going down the drain to a pan under the ref.
The drain starts under the cooling coils in the freezer but can be clogged anywhere. Some models will have access in the main ref in the top - rear, a small cover can be removed. Some will have access on the back of the ref. you can see the drain tube and an elbow where it come out of the ref. remove the elbow and check for clogs.
Dec 11, 2008 | Whirlpool Refrigerators
Water Leak
pull the funnel tube out of the back wall and clean the drain that goes out the back wall of the refrig section
Feb 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
138 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
