Question about Eljer Toilet Onepiece Canterbury 081162047
Want to know how to remove the flush alve on a one piece toilet.
  • 20 Answers
Open the rear lid of water closet. on the very inside rear of the flush valve there is a very then nut it unscrews in the clockwise rather then counterclockwise. I think that was the problem
Posted on Jul 12, 2009
Koehler one piece toilet trickling water into tank
The flapper at the bottom of the tank is leaking and needs replacement.
Feb 08, 2014 | Kohler SAILE ELONGATED ONE-PIECE TOILET...
How to fix a running toilet
Inspect the inside of the tank, there are two things that can cause this:
1. Water level is too high and the water leaks into the overflow tube in the middle BEFORE it is able to shut the water off.
2. The seal at the bottom of the tank where the flush valve is, has a problem because the chain or something is stuck in it. The seat that the alve rests on is bad or the valve itself is bad or the handle chain is too short.
Apr 18, 2013 | Home
I have to replace the gasket which the flush valve sits on. How do I remove the flush valve. The toilet is Kohler 1 piece model K-3323
The top of the pipe above the flush valve is threaded if you unscrew this you will be able to remove the flush valve and replace the gasket. I am assuming we are talking about the same here is a link that has all the parts:
http://www.plumbingsupply.com/kohlertoiletparts-santarosa.html
Oct 24, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
One piece toilet needs a new gasket. How do I replace it?
The top of the pipe above the flush valve is threaded. Unscrew it, and you will be able to remove the flush valve and replace the gasket.
May 30, 2010 | Kohler - Toilet - One-piece - Santa Rosa -...
Toilet acts like it's getting pluged up as soon as you flush .
use a two gallon buck to flush your toilet - you pour the two gallons directly into the toilet bowl if it flushes fine you need to replace the flush valve, as it is not letting enough water through to properly flush the commode. either rebuild the flush system in the tank or install a fluid master and have a good nights sleep knowing that in the morning you will not leave a suprise for someone else in the family.
Mar 15, 2010 | Gerber Blades Gerber Ultra Flush 10" White...
My toilet does not flush properly. It seems to
You might check under the rim of the toilet, there are about 12 little holes that when you flush water comes out to start the most important part of the flush. The swrill, with out it hard to flush. Talk a piece of wire hanger ( I know "NO WIRE HANGERS") and use it to push up into the holes. Hard water deposits sometimes build up there.
Sep 27, 2009 | Home
Eljer Canterbury one piece remove flush valve
I had the same problem and contacted Eljer and they sent me the above instructions to make a tool to remove the flush valve.
Sep 09, 2009 | Eljer Toilet Onepiece Canterbury ...
Kohler one-piece has no flushing power
Hi
try to increase the amount of water for each flush .
Jul 17, 2009 | Kohler Toilet - One Piece with Ingenium...
Flush valve
it is all one piece,replace it with the same model. a plumbing supply house is the only place you will find what you need.
Jul 01, 2009 | Eljer Toilet Onepiece Canterbury ...
Eljer Toilet  Onepiece  Canterbury  081162047 Logo
165 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
