Question about Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range
F1 error code, continual beeping all other oven functions work properly
The beeping can be stopped (temporarily) with a cancel function or other entry on the touch pad, or by shutting off at electrical panel. All other functions of oven work properly......how to eliminate and resolve the beeping and repair the annoying problem. Hours or days may go by without beeping and without any apparent use of appliance (3:00 AM) the incessant beeping starts all over again.
  • 1 more comment
  • Skyedogp Nov 16, 2007
    Fridgetech,
    Thank you for the helpful response, which I rated highly. There was nothing inappropriate in your response. I sent an e-mail to the website as the problem I had posted was redundantly posted twice. I reported that I had mistakenly made an entry that was ia duplication and an error. I am sorry they reported it to you as an inappropriate response. thanks for the help and sorry for the misunderstanding.
  • Anonymous Nov 19, 2007
    I have a jenn-air in wall oven and it has aproblem about the same. While not in use, it starts beeping and shows F-1 in display. You can hit reset and stops and you can still use the oven.
  • Alex Spassoff
    Alex Spassoff Jul 07, 2008
    Beeping F1 error code. Cancel stops it for a minute. Circuit breaker stops it for about 1 hour.
  • 473 Answers
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Posted on Nov 09, 2007
  • Craig Shelton
    Craig Shelton Nov 16, 2007
    Why was this inappropriate?
  • Craig Shelton
    No problem, hopefully they will fix it.
I turned on my self cleaner oven this morning and it started beeping and flashing F1. The only way I could stop it was to push the cancel button which of course turned it off
Good Morning Monica, thank you for your post!
Based off what you have described your Frigidaire range is providing you with an error code of F1 after you started a self-cleaning. The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the F1 error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
Dec 06, 2015 | Frigidaire Kitchen Ranges
My oven keeps displaying the symbol "F1" and continuing to auto-clean
Try pressing the stop/cancel button, if this does not work unplug stove and wait five minutes and then plug back in, this should clear the display
Nov 16, 2009 | Frigidaire FEF366EC 30" Freestanding...
I HAVE A GE ELECTRIC OVEN AND THE F1 CODE CAME ON OUT OF NO WHERE AND I AM UNABLE TO GET IT TO STOP. I FINALLY TURNED OFF MY CIRCUIT BREAKER TO THE RANGE HOWEVER AFTER SEVERAL MINUTES AND TURNING BACK ON...
F1 = Failed transistor in control
If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad
You'll have to use the breaker to keep it off. The ERC is AKA the Clock.
It handles all the functions of the oven, and is a costly repair.
Usually recommended to use the $200 to upgrade to a more efficient oven with a warranty.
Thanks for using FixYA - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 11, 2009 | GE Ovens
Kenmore oven control beeps and shows F1
According to Kenmore's list of error codes, F1 means EOC (Electronic Oven Control) failure, and the solution is to replace the EOC. You might look into that. The part itself costs around $80, as far as I can see.
Aug 24, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Dacor oven beeps and shows F1 code
-F1- Alarm “System Watchdog Circuit”
The system will detect a failure in the internal watchdog element relay circuits and will activate a
cancel feature. F1 will be displayed in the time digits and will beep until the cancel button or another
function is selected. An F1 failure could be detected in cook or time of day mode. With an F1 failure
the ERC is picking up a command to supply heat without receiving an input from the membrane. The
watch dog circuit is designed to prevent this.
If the beep continues after pressing cancel check the main control (ERC)
Dacor
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
GE oven functional code F1 appears.
Hello, I come across this problem quite often, The f1 error code does not always follow that it is a bad EOC (Electronic oven control) This could also be a problem with the touchpad. The way to figure which is bad is turn electric off, access the EOC and pull the wire harness/ribbon tape for the touch pad. Reassemble the range and switch power back on. If you are still getting the F1 it is the EOC..If the F1 clears then your problem is with the Touchpad. If you have any other questions please feel free to comment again. Good Luck!!! Mike
Aug 18, 2009 | GE Kitchen Ranges
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
What does the F1 alert mean?
Hello jiverson,
Welcome,
You said, your get a recurring F1 beep even after I press "cancel" I worked with the oven for about 2 hours trying various combos of opening the oven, pressing cancel and trying to perform various functions (light, clean, bake, broil, etc.) to no avail. I got it to stop for about an hour at one point, but it started right back up again. It also seems that every now and then the oven light will come on all by itself during one fo these alerts
Please send me your complete model number including the single diget at the end of the model number.
For example: FGB24S5AW1
Then I can be sure!!!!!!!!!!!
Waiting your response. I'll check for it through out the day!
And get back to you as fats as possible so you can take care of it Monday!
Huuum
In some ovens It could be failure of your, EOC (Electronic Oven Control) failure
Oct 19, 2008 | Frigidaire FGB24S5A Gas Single Oven
Dacor Epicure ERD30 Dual Fuel (Electric and Gas) Kitchen Range Logo
1,138 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
