DCR-HC38
SOURCE: I have a dcr-hc38 that shows C:32:11 error and
eject mechanisum connect by a stip that one break u cant ching that strip u must u chaing mechanisum
SOURCE: When I insert the cassette into the camera it won't close.
Try the following link to troubleshoot this issue:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C190805
SOURCE: Sony DCR-HC38 error C:31:22 re-insert tape.
Sony is a ******* piece of **** corporation that has foisted their name on professionals and consumers as being the epitome of high technology for all forms of media. They are, in fact, scam artists that have perfected the art of programmed obsolescence and early life failures for their equipment. Because I have been a professional video/audio engineer for 30 years, I have been forced to own and use more Sony gear than I am comfortable admitting to. There is NO answer to your dilemma because it is a defect programmed into the circuitry of Sony DV-Cams that will ultimately force you to take the machine in for repairs...again and again and again and again....
Do your self a huge favor and smash that piece of **** with a sledge hammer right now. Then, go out and buy a Canon. Great products and great tech support. Sorry I couldn't solve your problem for you. But, I am an engineer and I can't even solve this one myself.
SOURCE: DCR-HC38 computer not recognizing camera
Option 1:
If you want to use the USB cable to connect the Camcarder to the Computer to transfer the video to the Computer then:
(Applicable for Vista Operating System Only.)
This Camcorder does not support USB streaming with the VISTA Operating System. Use an i.LINK cable to transfer the video to the Computer. The i.LINK port is also called IEEE 1394 or Firewire port.
(An i.LINK is a black D shaped connector with 4 or 6 pins. The type of
cable to be used will depend on the i.LINK port of your Computer. The
Sony Camcorder will have the 4 pin i.LINK cable and if the computer has
the 6 pin i.LINK port, then you may have to use the 4 pin to 6 pin
i.LINK Cable).
You can use any video capturing software like Windows Movie Maker to transfer the video from the Camcorder to the Computer.
Refer this Link for the instruction to transfer the video to the Computer using i.LINK cable.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C111893
NOTE:
As the Camcorder does not support USB streaming with Vista, it is not
required to use any Sony Device Driver to transfer the video to the
Computer. You do not require any Drivers or Software from Sony to
transfer the video from the Camcorder to the Computer using the
i.LINK/Firewire interface.
Option 2:
(Applicable for Windows XP Operating System only):
If
you are using a Windows XP Operating System then you have to install
the USB Streaming Driver in the Computer from the supplied Software
disk with the Computer.
Check this Link for the instruction to transfer video to a Computer using USB Streaming.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C222820
If you do not have the supplied Software disk then I suggest that you use the i.LINK cable to transfer the video.
Good Luck!!!!!!!!!!!!
SOURCE: Can not copy MiniDv to Mac 10.6.2
usb is not compatible with mac os. so, use a firewire/i.link cable to transfer the videos to the mac computer
Testimonial: "jvmathu I really appreciate your help! I am going to find the cables and try to copy the video. was very helpful to find answer for this task. "
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
