Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I need to know where the least expensive briggs 31q777-0136 engine for my rider can be purchased. Also will any other engines swap out with this?
    Problem Solver:
  • 5 Answers
I can order you one for 450, graysmallengine@mail.com
Allyn
Posted on Jul 02, 2009
  • 376 Answers
Do you know that the first two numbers indicate the ci of the engine? You have a 31 ci engine and you can find that engine rated from 15.5 hp to 20 hp, depending on what the brand seller wants to say it is. They can underrate and engine but they can't say it larger than it is. So Sears can sell a 42" cut with a 15.5 hp engine on it or they can put the same engine on a 48" cut and call it an 18.5 hp. Both being 31 ci engines. My point being... find the cheapest 31 ci engine or even a 33 ci. Either will fit right up. The only problem you may encounter is the charging/wiring system may be different, but all you would have to do is put the alternator and harness off your old engine on the new one. That being said, do an internet search for an engine and let me know what you come up with and get back to me. I probably can save you some money with possibly a minor inconvenience of changing out the charging system. Dwain
Posted on Jul 01, 2009
  • Dwain Pippen Jul 05, 2009
    Cool... Make sure you're getting a new, complete engine with a two year warranty for $450.00.............
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Why doesn't throttle control work on snapper rider mower with briggs and stratton engine
I need a little more information. Does it run at an idle or is it runing at a moderate to high speed? Does the throttle lever move or is it frozen?
Jun 24, 2014 | Briggs & Stratton Garden
Why is my 22 hp 42 inch deck craftsman rider mower oil leaking somewhere in th fron of the engine
i need more info where is the leak near also check oil level if its to full it will blow by to the intake
Jul 29, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Wire a briggs where a kohler was
there isnt an easy way to wire a brings engine to a kohler wire harness , best thing is to get a harness from another rider that came with the briggs and use that harness . best place i would know to look is try criagslist. org and post in the farm and garden section for what you need . or least see if someone can send you their model info so you can order the wireing harness . this is the best and easiest thing i know to do .
Jan 01, 2012 | Craftsman Garden
I have a 17.5 B&S engine huskee42" cut rider,
If you have OHV engine go to smalleng.com and watch vid on how to adjust lifters.
Mar 09, 2011 | Briggs & Stratton Garden
Have a Yard Machine riding mower with 21hp Briggs Stratton engine OHV/IC V-Twin. when I turn on key nothing happens. How many switches control the start motor from the ignition and where are they located....
It depends on the model but most riders have the following;
1. Seat switch
2. Brake pedal switch
3. PTO switch
4. Neutral switch (if its a shift model)
All need to be closed in order to start engine.
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I need to know how to take out the camshaft and how to put in a new one on a 15 horse poulan rider
you must remove engine from unit. then loosen rocker arms and remove push rods. remove oil sump from bottom of engine. use a screwdriver to push lifters up,(a bit of grease helps them to stay up, very helpful at reassembly) and remove camshaft.
Jan 18, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
162 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
