Question about Frigidaire PLMV168 Microwave Oven
I need to replace some flex conduit that was used to vent from a frigidaire over the range microwave to a vent pipe in the ceiling. Now that we are selling the home, the inspector called out the flex piping as a fire hazard that collects grease. We want to replace the flex with a solid elbow of sheet metal. Do you know what size should fit?
    President:
  • 1,185 Answers
100mm or 160mm or 4" or 6"
Posted on Jul 01, 2009
Do i need a special vent kit to vent microwave to outside
Yes, an adapter/kit should have come with the unit and then you would have to buy the piping etc.If you do not have the adapter/kit get it from the manufacturer or unit seller.
Sep 12, 2014 | Samsung 2.0 cu ft Over-the-Range Microwave...
Frigidaire gallery otr microwave vent not working
Hello Lori Wilson - Thanks for your post! Generally speaking, the vent is not very strong. Try to place a single paper towel on the underside of the microwave. With the vent on, it should suction the paper towel to the bottom of the microwave. If not, I personally recommend contacting the installer to verify that the vent fan is installed properly and the exhaust outer is correct.
Apr 04, 2013 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
I currently have a non-working over the range microwave, I have bought a replacement. How to I take one down and replace it with the new one?Are the brackets interchangeable?
What brand Microwave are you removing and what brand are you installing? If the are not the same brand they will mount differently. On an older GE you remove the two screws holding the unit in place. They are located on top of the unit on the front. Look in the cabinet above the microwave. After you disconnect the vent pipe the unit slides forward and out. On some other brands the unit will pivot down and then you lift it off a mounting bracket. To make the job as easy as possible and to make sure the vent pipe does not have to be moved, remove the old unit before buying a replacement. Look at how it mounts. Then buy the same brand and it should mount the exact same way, so you could use the old mount. But even then the manufacture may have changed the way it is mounted. I just replaced a GE with a Whirlpool and they mount completely differently. I even had to move the vent pipe 2" to the right. So stick with the same brand and hope they have not change the mount.
Dec 15, 2009 | Microwave Ovens
Handle on Frigidaire Microwave broken, probably because of heat from gas burner below - this is a defect becaquse the microwave oven was manufactured to be built-in above range. Frigidaire has finally...
im kinda confussed as to why Frig would do that,,,
but if you send the model number im sure we can help
most times repacing the door is really just a matter of lifting it off the pin hinges after you have removed the vent
but i can be more clear with the exact model
Oct 28, 2009 | Electrolux Microwave Ovens
Tappan over the range microwave - exhaust fan problems
most microwaves do not blow air out the bottom.They pull air from the bottom and blow it out the top.
Aug 31, 2009 | Frigidaire Over-the-Range Microwave
No vent for over the range microwave.
Have you selected a microwave yet?
many over the range types can be vented inside if a charcoal filter is used, which you must replace about every six months.
Otherwise, you will need to install a vent system in the kirtchen.
Aug 20, 2009 | Microwave Ovens
I was given a Whirlpool microwave. I think it's 6
Not really over the short term, if the vent discharges back into the room. If it is of the type that discharges through the ceiling, you could have grease build up in the vent over time. I found replacement generic filters the other day at Lowe's. But, I wasn't looking for filters at the time. Check there or a similar store.
Good luck,
--W/D--
Jul 20, 2009 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
Safety hazard if microwaves dont vent straight up?
As long as the air flow is good, gravity shouldn't make any real difference.
For more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 14, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Connect microvawe vent to exhaust pipe on ceiling
I would call Sears service (and ask for the manager) every day until they send the guy back with the right parts!
If that somehow doesn't work, you can order the parts at the Sears parts site.
You can find out which parts you need in the owner's / installation manual. If you don't have it,
you can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Dec 25, 2008 | Kenmore 63792 Microwave Oven
Frigidaire PLMV168 Microwave Oven Logo
97 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
