Question about HP Compaq Presario V2000 Notebook
Presario v2000 won't show the color black
Colors are way off. Display is set to 32 high. Diagnostics say the monitor is having problems with the color black. Can this be fixed?
    Scholar:
  • 95 Answers
Hi
well actually there are no such manuals available as they suppose this works belongs to engineers only.
but i cn suggest you to read this manual before u try fix it up.
http://support.ts.fujitsu.com/com/support/manuals.html
thnx
dun forget to rate me
Posted on Jul 01, 2009
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
My compaq presario v2000 has a fuzzy screen and the colors on the backgrounds that are supposed to be white are like and aqua green color and i was just wondering how to fix it. Is there something i can...
First thing you want to try is getting the laptop to display on an external monitor. If it doesn't replicate the same issues then you know it is either the screen or the inverter/backlight.
if it does then it is most likely a motherboard issue and sadly can not be fixed outside of replacing the board.
Dec 10, 2009 | HP Compaq Presario V2000 Notebook
Colors in PAINT are limited
assuming you are using XP-
1. right click on your desktop and select "Properties"
2. click on the "Setting" tab
3. make sure that the color Quality is set to "Highest 32 bit"
4. you can also:
  • click on "Advance"
  • find the tab of your graphic card
  • make sure it is on settings that allow high quality of colors
Apr 26, 2009 | Computers & Internet
Screen colour not matching the printed pages
Unfortunately that's the age old problem of matching colors between computers and printers. Your printer is probably not the problem, that's why he couldn't fix it. Even though your monitor is set to default values it doesn't mean that your colors are correct as colors can vary from monitor to monitor and the color temperature is probably too high causing the colors to look lighter than the printout. The picture on the monitor may look good to you, but it's not set right for matching printer colors. Monitors use RGB (Red, Green & Blue colors) colors and printers use CYMK (Cyan, Yellow, Magenta & Black) colors and you have to make them get the results you want. You will have to do some tweaking of your monitor's settings to get it to match the printer output. Below are some links that will help explain things better and maybe help you adjust your monitor.
http://www.colorwiki.com/wiki/How_To_Get_My_Monitor_To_Match_My_Printer
http://answers.yahoo.com/question/index;_ylt=AjWgmLYL.EGyC5z6hTuiEILty6IX;_ylv=3?qid=20090405191851AAl0xOq&show=7#profile-info-R3GCvDlKaa
http://www.hex2bit.com/products/product_mcw.asp
Feb 28, 2009 | HP LaserJet 3600dn Printer
Display blinking and turn in to white color with black lines
no its not a driver you have a video chip getting ready to fail.on the v2000 it intergrated in to the mother board. soon you will be joining many other compaq v2000 and m2000 owners in the search for a mother board compaq has updated part numbers it a whole differant board for these units due to having a common failure rate of the original mother boards.Compaq know there was a over heating of the video chip that leads to failure but has not offered any assistance to there customers. john@johnslaptops.com
Feb 17, 2009 | HP Compaq Presario V2000 Notebook
Display Problem Black turns Red
sounds like you have a loose connection ....either into the screen or into the motherboard....the connection between board and screen runs through the hinge brackets and often comes loose after machine has been opened and closed a lot.....need to be comfortable opening up laptops to check the cables as it can be tricky to get to the back of the screen where the end of the ribbon cable is..
Dec 13, 2008 | HP Compaq Presario V2000 Notebook
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Presario v2000 notebook problem
Put another monitor and go to the display settings settings advanced and there u can configure display settings if it wont work so just change the monitor
Oct 20, 2007 | HP Compaq Presario V2000 Notebook
Tiny Monitor
Out of frequency means your video card is trying to display a resolution beyond the capability of you monitor. Typically it is really a combination of too high a resolution and too many colors. Typically a 19? CRT will be set to display at a screen resolution of 1024 x 1024 with the color quality at 32 bit or *true* color. Personal preferences differ and you can set it lower or higher, depending on the capabilities of the monitor. Let us know if you have any other questions and please don?t forget to rate this post.
Mar 02, 2007 | Tiny Computers B1996 19" CRT Monitor
Monitor colors "pulse"
What video card do you have?? Some older video cards don't display very well at higher resolutions... You may want to get the latest video card drivers which may help the problem.
You can find out what card by opening display settings and going to the screen that shows the 1280x1024 resolution.
Let us know how it goes
Oct 22, 2006 | LG Flatron L1951S 19" LCD Flat Panel...
HP Compaq Presario V2000 Notebook Logo
46 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
