Question about Philips 42PF9630A 42 in. Plasma Television
I have exactly the same problem.
You can hear a relay drop off line and it will not come on. When it doesn't start the power light flashes red. Once it starts the picture is fine but sometimes it takes 30 min turning it on and off before it will come on.
  • 197 Answers
You could have bad capasitors in power supply
Posted on Jul 01, 2009
TV does not turn on? (Relay problem?)
The power supply could be failing intermittently. That's why it sometimes works and sometimes doesn't. Also, the relay could be erratic.
May 26, 2014 | Funai Magnavox 40" Class 1080p 60hz LCD...
TV stopped working
Since no brand etc listed here
Google the model number with 2 blinks and look at the results, you may find on another forum the answer to what it means and even a answer--error codes tend to be general in nature so do not expect it to point to a specific part.
Dec 19, 2012 | Televison & Video
I cannot stay connected to internet, my model 2701HG-B 2wire at&t dsl will start flashing red then disconnect me from the internet or my game site, how can i get this to stay fluently connected please!
You might want to try disconnecting everything EXCEPT the power cord. If you still get the red power light (it should stay there forever) then bring the gateway to Radio Shack or somewhere they have a 5 volt DC @ 2 amp power supply and plug it in for 5 to 10 minutes and see if the power light then stays green. If it stays green then all you need is a new power supply! If not, then the gateway is fried. Mine keeps going from a solid green power light to a flashing green power light and I can hear a relay click every 2 minutes at which time a pop-up say "ethernet line disconnected". I tried new power supply etc. to no avail! It is fried after 1.5 years! No more 2wire for me!
Sep 28, 2010 | 2wire 2700HG-B Router (2700HGB)
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Gmp100-4 initer lows and I can hear gas for a few
The red blinking light just means that it went into lock out mode from to many attempts to start. If your igniter is glowing and you do hear the ''hissing'' sound, than your problem is there is no gas or not enough. When installing a furnace for the first time, you some times have to bleed the gas lines, other wise you get the exact same problem your having. If you have a flexible gas line, unscrew one side with the gas on to bleed off the air in the system, if it's all hard pipe, you will have to undo the union and bleed it that way. Hope this helps and good luck!
Mar 13, 2010 | Goodman GMS90703BXA Heater
My pioneer plasma PDP 5060HD Media Center control box has red blinking light, blinking once every second. No power to plasma display and unable to power on media center box. Recycled power to both plasma...
lenwas,
I have the exact same problem with the same model tv. It just stopped working, tv has no lights or evidence of power and the red standby light on the media center flashes without any other function potential.
I checked the internal tv fuse and it was measuring continuity.
If you figure anything out I'd be interested to hear it.
Tom
Jan 05, 2010 | Pioneer PDP-5060HD 50 in. Plasma...
Turning on green light starts flashing only to hear a click and then the red light starts flashing... tv will not come on.. i can hear a fan that seems to start up...
The power up sequence is being interrupted and this could either be the main power supply or a protective shutdown of the supply because of a downstream failure. The clicking you hear is the activation and dropout of a relay.
If the flashing seems to be in a pattern, it may be telling you what has failed via the coded flashing. Any Sony service (or service tech) can tell you what the problem likely is if there is a pattern to it.
Nov 29, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Tz61v61 toshiba 61 rptv theaterview
If the relay clicks you most likely have a leaky diode or bad transistor in the stand by or start up circuit. There is a manual available for that model called. Toshiba Power Supply and Shutdown circuit Troubleshooter. Its available at the following link. It gives step by step instructions so you can figure out exactly whats wrong with your set. The site emails it too you after you place your order and they also provide free unlimited tech support so you will have a resource for help if you need it. I am one of their on line support techs. I highly reccomend that Manual to any one with a toshiba that will not power up. Here is the link.
http://servicemanuals.vstore.ca/
Apr 12, 2008 | Toshiba TZ61V61 61" Rear Projection...
Flashing Standby/Stero light and No picture.
How good is your picture when it did come ? Is it as good as it once was ? Or is it alittle washed out. If it is washed out the picture tube is weak . Sometimes turning up the screen control alittle would solve problem but if you turn it up too much you would have faint white line running diagonally. Now if you think the picture was good before you this problem video circuit would be your suspect . Jungle IC or something in the RGB circuits . Good luck
Feb 27, 2008 | Sony KV-35V35 TV
Wont power on
Face it....your big screen is a Flasher. but read back,,, I think you asked this before...go back about 1 or 2 months and see my solution to this exact problem. but bottom line..you need a tech. good luck
Sep 01, 2007 | Sony Grand WEGA KDF-55XS955 55" Rear...
Philips 42PF9630A 42 in. Plasma Television Logo
121 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
