Question about Logitech Harmony 890 LCD Remote Control
My cable company came out yesterday because I could not get a picture but could get sound. They used the cable remote and fixed it. However, after they left, I used my Harmony 890 and could not change channels. Only thing I could do was to turn TV on and Off. I have called Best Buy where we bought the flat screen TV along with the very expensive remote and they wanted to charge me $149 to come out and reprogram my remote. PLEASE HELP!! I am 74 years old and I am not going to pay that to get the service that I need. Can you help me or give me instructions over the phone? Bobbie Burnett Stressed in Cleburne, Tx
  • bbb2 Jul 01, 2009
    I do not want to buy anything else, just want help with what I have.
  • 3,230 Answers
Go to the below link and purchase a universal remote -
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&langId=-1&XID=O:rmvl600%2Fbstock:dg_ggldf&productId=8198552921665092997
This costs only $14.95
Thanks
Posted on Jul 01, 2009
  • Mukesh Kumar Jul 01, 2009
    Your old remote is gone dam so now you need a new remote, thats whay i'll give you a link to purchase a cheap remote.
I was trying to set the cable box so the remote that came with the cable box would opert the tv and i lost the picture . the blue button comes on and off but no sound or picture the remote that come with...
Make sure you are on the correct input on the television and that the cable box is on. Do this manually. Hopefully you will get picture and sound again. If yes, then check the cable company website for the remote codes for your television manufacturer and the instructions for programming. Often times there are multiple codes for each brand so be patient.
Apr 08, 2014 | iLO Televison & Video
I have a no signal prompt on my jvc flat screen, the Verizon fils box is working, how do I fix it?
Make sure you have selected the correct INPUT. Many TVs have several from which to choose. Locate the INPUT or A/V button on the TV or remote. Press it once and wait up to 3 seconds to see if the picture appears. Repeat to cycle slowly through all inputs until picture appears. Some TV / remotes have buttons labeled AV1, AV2, AV3, etc. or similar do go directly to the specific input as opposed to cycling as above. Press each - one at a time - and wait up to 3 seconds for picture to appear.
If unable to display a picture, check A/V cables at cable box and TV. Note which input is being used on the TV for the cable box. Then select the same AV input on the remote that is being used on the cable box.
If still no picture, contact cable company / Verizon for service.
Jun 26, 2013 | Televison & Video
NO signal since yesterday in area SY7 0QF on Tv can not get any picture or sound was working before
If there is no signal in the area.
I mean, if the problem is extended to more than one TV set, then call the TV provider company.
If the problem is concerning cable TV (eg. NTL, Virgin), then a local node may be faulty.
If the problem is only on your TV, and the TV has no signal, or static, then check aerial, aerial cables, receiver box and signal booster if present.
If you use cable TV, check wires and receiver box.
If you have Sky TV, then check if you have sat signal, check box and cables.
If you do not find anything wrong call TV company.
If instead your TV stays off with power led on or blinking, then the TV is in fault mode (protect).
Try leaving the TV unplugged from power for one hour. If that does not fix the problem, then call the number listed on the owners manual for support, or ring a local technician.
Sep 04, 2009 | Tvone LM-1501R 15" Flat Panel LCD Monitor
VIZIO VS42LFHDTV10A Freeze Up
Just unplug the comcast and see how the tv works, if the TV works fine, then you will now the trouble is not your TV.
It is not likely to have the same issue in the new TV, just unplug everything and use a dvd to see how it handle it.
Jun 19, 2009 | Televison & Video
I want to use the picture in picture feature
  • I had the same problem and i bought a universal remote at walmart for $15. the name of remote is phillip but any was you may have to turn cable off to set picture in picture. hope this was helpful!!
Mar 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Mitusbishi WT 42385 HDTV. Having a problem getting the HDTV to work. I do not have the remote, but when you set it to HDTV channels it only shows snow in the picture. The sound works fine. Can I do...
After the work we did with your rep to resolve the issue we determined that we did not have a means to fix the problem. Your rep suggested to call the cable provider and have them run a test signal. They said that would probably fix the problem, but if it didn't they may need to change the cable box. I contacted the cable company and they ran the test signal which did not work so yesterday the cable company sent a technician out and they changed the box. This corrected the problem and the HDTV is working great. Thanks for the help even though it did not work by your solution directly, you did lead me to resolve the problem.
thanks
Jeff Knight
Jan 03, 2009 | Televison & Video
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Aug 22, 2008 | Audio Players & Recorders
Logitech Harmony 890 LCD Remote Control Logo
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
