Question about Fujitsu Siemens LifeBook P7120 Notebook
Screen flickers from red to blue to green. Must be a loose wire or contact somewhere. Is there a manual for opening the P7120?
  • 197 Answers
Flickering means your monitor is faulty. you might need to replace it.
if machine is under warranty i believe the replacement is free.
Posted on Jul 02, 2009
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
Lg r405 laptop screen flickering
most likely a loose connection if it is flickering.. if there are red squiggly lines usually means driver issue.. and if there are blue banding lines, typically means the chip is overheating/desoldering.
Mar 07, 2013 | LG R405 LAPTOP LCD SCREEN 14.1" WXGA CCFL...
I have a 1999 Honda Shadow 750 ACE the marker lights are flickering and it backfires on decell after steady throttle, what could be causing this? I have tuned it up and cleaned the carb but it still does...
To help stop the popping replace the copper head o-rings and muffler to head pipe seals. Backfiring is typically caused by air leaking into the exhaust and igniting unburned gasses. Flickering lights indicate bad wire connections/grounds. Honda grounds the turn signals through the green wires. You will probably have to take off the seat and open up the headlight bucket. Try unplugging and replugging the orange,blue, and green wires going to all four turn signals. This should take poor contact and grounding out of the equation and sort out your flickering lights. Also go to the fuse box and take out the fuses one at a time and reinstall them. Make sure that the end caps of the fuses are not loose, if so, replace the fuse. Broken ar cracked fuses on older bikes can cause head scratching problems where there aren't any. Make sure that all your turn signals are grounded through the green wires.
Sep 05, 2010 | Honda VT 750 Shadow Aero Motorcycles
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
Picture is very green & blue very little red
caroldickers,
if the picture have lost red, possibly there's a loose contact somewhere in C-board area of your screen. The only way to revive the red color is to check and resolder the c-board are.C-board is located at the back of the CRT unit.
Jan 14, 2009 | Televison & Video
Screen flickers
Check for multiple poor solder connection on the sweep/power supply board.
or.
just need to balance the three colors red,green and blue that may help. remove the front covers and look for black module that have screw and focus controls just move little bit left or rightbe carefull because you can loose the picture.
Sep 24, 2008 | Televison & Video
Red CRT is dim....
Yes I did. You will need to get a service manual for this TV set to trace the voltage coming from the sweep power supply. If this is a problem that is new after you replaced the convergenbce4 board, you for sure have a broken wire or connection somewhere in the set. Have seen this happen may many times after a novice repairs a TV set. Good Luck
Sep 06, 2007 | Samsung HCL4715W 47" Rear Projection...
Fujitsu Siemens LifeBook P7120 Notebook Logo
400 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
