Please clarify the question. If you mean tax withholding rate, change the number of exemptions on your W-2. That won't change your tax liability at the end of the year, but will change your take home pay. If you mean actual tax rate, then you need to change the amount or source of your income, or change your tax deductions. Regarding source, I mean earned income vs investment income.
SETTING YOUR TAX RATE you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes: hold set% button hit tax+ button change the desired % hit set done Do rate the solution.
To program a sales tax rate of 6% 1 Find your sales tax rate. You may need to contact your local government office. 2 Put the PRG key in the Mode key slot and turn it to the PRG position. 3 In the round Number keys area, press 1 and then press the Tax 1 key. 4 Press 6000 and press the Amount Tend Total key. Your sales tax is programmed.
I'm in Australia and only going on the program manual for your area, it states that canadian tax is tax on tax? if this is true then you probably entered a code for add on or add in tax and thereby changed it all.
you need the following
tax table address
1 125
2 225
3 325
4 425
rounding off codes
rounding off to 2 decimal places is 50
rounding up to 2 decimal places is 90
cut off to 2 decimal places is 00
tax system code
tax table with out tax rate 01
tax table with tax rate and add on rate 02
add in tax rate 03 Canadian tax-on-tax rate 04
starting point
to get the starting point you multiply by 100 and subtract 1
eg 50 cents = 0.50 X 100 - 1 = 50 - 1 = 49
eg $4 = 4.00 x 100 -1 = 399
to program the tables go through these steps
go to program 3
tax table address eg 125 subtotal
tax rate ca/amt tend
starting point eg 0.50 = 49 ca/amt tend
rounding eg 50
tax system eg 04 ca/amt tend ca/amt tend
here you have 2 choices,
press ca/amt tend to go to the next tax table ie 225 and start over by entering the tax rate and go through the procedure again
or
press subtotal to finalise the tax table you are on
