Question about GE Dryers
The dryer is not dryer the cloths. I think the lint filter is clogged
  • 1,305 Answers
Your lint fllter should be readily accessible and should be cleaned before each cycle. If this has been building up for a whle, I highly recommend cleaning the interior of the dryer. This requires removing the front panel and vacuuming the lint out of the machine.
Be careful not to touch any of the heating elements with the vac.
Also it is a good idea to clean the exhaust vent periodically. Detach the flex connection from the machine and check that it's not plugged as well. Hope this gets things dryin' again.
Let us know if you need further details.
Posted on Jul 01, 2009
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
Tip
Most overlooked dryer energy savingr problem ever!
First, you must know that a common clothes dryer is really a water pump. It pumps water outside by
heat convection. Just because its hot doesn't mean its drying clothes efficiently.
The tip here concerns the filter. If you think your filter is clean, look again. You may have cleaned
all lint from it but it probably is still ineffective and energy draining.
Do this. Place your filter under a trickle of water in the sink, after lint removal as you usually do.
The water, most likely, will not go through the filter. What happens is that water promotes scale and clogs
the filter. (well you've got water being dried by heat which leaves scale.) This scale (or stopped up filter)
can cause a great deal of extra running time, and a dryer uses a lot of energy. (Electricity)
Scrub the filter with a bristle brush and dishwashing liquid and then run water on the filter again.
You can see how much more the water runs freely through the dryer filter.
Dry the filter, and reinstall. It's so nice to save a great deal of electricity!
You can see how the wet air is not moving the water out of your clothes very efficiently and it also
can cause the dryer to overheat too much so that the thermal switch (or fuse) blows thus causing a
expensive service call. (Most won't even tell you about the scale clogged filter anyway) Because most
don't know it either.
Enjoy your savings!!!!
imufo2
Leo Ponder
imufo2@sbcglobal.net
on Aug 25, 2010 | Dryers
Clothes won't dry
Mar 27, 2014 | Kenmore 67032 Dryer
Lint is stuck in door seal and clothes are not drying
sounds like the lint filter is clogged up, replace it with a new one if possible or give the old filter a good wash, let it dry and try again
Jun 03, 2012 | LG DLE5977 Electric Dryer
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 20, 2011 | Whirlpool LER3624JQ Electric Dryer
My dryer keeps saying Lint Filter Problems and cutting off however the lint filter is clean. Because of this issue I the dryer will not stay on long enough to actually dry the clothes. It continuously...
try two things. first, run it empty without the lint filter installed. if it gives you the same error message, install the filter, but disconnect the flexible duct connected to the back of the dryer. try it again. if it still wont work, you will have to get it serviced and cleaned out. if it works with the ducting removed from the back, your dryer duct is clogged up. check your yellow pages for dryer duct cleaning. The lint filter error message is just your machines way of saying it is not getting enough air flow. It can be caused by a clogged duct also.
Nov 20, 2010 | Siemens Dryers
Ijwant to dry my cloth but when i turn on it appear check filter how i am going to fix
You should empty the lint filter. The lint filter catches all the lint from your clothes and will need cleaned occassionally. I clean my lint filter after every load. Towels usually clog the filter faster than other clothes.
Aug 07, 2010 | LG DLG5932W Gas Dryer
My dryer is not drying the clothes. It is a self venting dryer and I clean the filter everytime but the clothes are not drying. The filter light keeps flashing and I think the dryer is turning off.
check the out side vent and make sure that it is not blocked with lint also make sure that the ducting is not kinked or has to many curves in it that will hamper the effects of proper drying
Jun 09, 2010 | Dryers
My kenmore 80 series dryer doesn't dry. What should I check? It runs fine and heats up but the clothes are still wet
Whnn a dryer is hot but does not dry the clothes it is a very good indication that the dryer vent, ducting and or internal air passages are clogged with lint build up. Also if you use dryer sheets the lint filter itself can appear clean but actually be clogged up with the softener material from the dryer sheets.
Clean all of the air ducts and passages with a crevice tool. Pull the lint filter and clean UNDER and around the lint filter. Make sure to go outside and remove any lint build up from the vent flapper. Pull the lint filter and wash it with white wine vinegar and a soft brush on BOTH sides. For some of the hard to reach areas a folded un half coat hanger works great for losening lint in those areas. DO NOT use anything sharp.
The dryer needs loads of air moving through the ducts to work properly. You may feel air movement but it should be a very high volume air flow. After a good thorough cleaning your dryer should return to normal operation.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | Dryers
Dryer thinks clothes are dry but they are not
1 start with claening the sensor strips located just inside the unit itself under the lint filter. pop yourheadinside dryer drum andyoull see 2 metal strips. witha scotchbrite pad, give it ascouruing, to remove any build up form fabric softener / dryer sheets
2 check for good, not kinked or clogged venting
3 replace the thermsitor about 30 bucks.
Mar 22, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
