Home | Dirt Devil | Featherlite Bagless Vacuum M085845Vacuum | No suction through top...
Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
Problem for Dirt Devil Featherlite Bagless Vacuum M085845Vacuum
No suction through top of hose - HELP
By csierra2066 on Jul 01, 2009
I cannot get the suction to work either. Is there something I am doing wrong? Is the little door the one at the bottom of the vacuum, I made sure it was open but there is no suction coming through the top of the hose when I place it in front of the dust or dirt I want to pick up. Help!
Solution #1
posted on Jul 02, 2009
Not Rated)
galati2k
Rank: Wiz
Rating: 84%, 136 votes
disconnect the hose where it goes into the clear tube on top of the base.there will be a little flapper door there when yo take it off.open the door and take a coat hanger with the end bent over like a hook and pull the dirt clog out of there.but first take the dirt cup off and remove the filter,if its clogged with dirt you won't have any suction.try using the vacuum without the filter in the dirt cup.if you have suction then then thats your problem ,a cloggeds filter
Was this helpful?
Yes
No
Solution #2
Not Rated)
gsohoover
Rank: Wiz
Rating: 83%, 36 votes
it might just be clogged
Was this helpful?
Yes
No
Popular Solutions for Dirt Devil Featherlite Bagless
Questions and Unsolved Problems for Dirt Devil Featherlite Bagless
Do you recommend Dirt Devil Featherlite Bagless Vacuum M085845Vacuum?
Answer
Answer
it just stopped working. it is only about 1 year old, the filter is new. stopped the other day... (More)
Answer
My roller is clogged with hair and is difficult to move. How do I remove it to clean away the hair?
Answer
I have a bag less featherlite dirt devil vacuum I bought n 2008. Whenever I vacuum dust goes... (More)
Answer
How do you wrap the cord around the vacuum cleaner without it keep falling off?
Answer
Model #085850. After emptying out the canister, I put the lid on backwards I guess and now we cannot... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dirt Devil Featherlite Bagless...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
