Has new batteries and new SD card
SOURCE: moultrie DGW-100 won't read sd card
check small switch on side of SD card; should be pushed toward contacts.Using the USB cable provided with cam, PC SHOULD RECOGNIZE DEVICE...might have to go thru windows explorer to find it, then use windows media player, or other, to open.
You are running 98 or later, right?
SOURCE: Moultrie cdc - 5.0
According to Moultrie you can try a hard reset.
Take out batteries, and SD card, hold on button for 2 min.
Replace batteries and try, haven't tried it yet, but will
SOURCE: SD card Locked
I have the same issue . . . tried new card, older card, 4 different cards, turned off camera, took out battery. I'm bummed.
SOURCE: moultrie D50 game trail camera won't take pictures in dark
Does the flash work? Could be flash circuit or day/night sensor.If you have another D40/D50 camera that flash works but has other problems,swap out the sensors.If not the sensor but the flash circuit then most likely one of the large charge capacitors which has to be soldered in.I use a digital multimeter with I/O capacitor test function..these caps should be about 250mfd.
