Where are the temperature controls for this fridge and does the freezer temperature control affect the fridge control?
SOURCE: Kenmore Fridge- all lights blinking
sorry to say this but the mother board has took a hit replace this and all will be well
SOURCE: Temperature Control not working on LG fridge
It is an error code. The thermal fuse in the freezer section has gone. It has to be replaced. To get by in the short term, uplug the unit for 15 minutes, then plug it back in. It will run until it hits the defrost again (approx 5 hours) Part location is 401A and part number is 6615JB2005C. It is easy to change once you get the back cover off. Plug in part.
Sgt 48
SOURCE: kg34na90gb fridge freezer - fridge
turn the freezer up to highest setting and set the refrigerator control to about half way. this will block some of the airflow into the refrigerator.
SOURCE: FRIDGE NOT WORKING FREEZER AT
We need some more information if you can get them so we can be more specific with our solution.
Do you here the compressor running for long times without stop or it work for some minutes and stop for some ?
Have you check at the back condenser coil, compressor if there is too much dust, have try to clean it ?
Have you try to manual defrost the freezer?
For how long do you have the problem?
Is it start slowly and it was becoming worst by days.
Do you have a themometer to give us actual temperatures in both fridge and freezer.
We remain
Kenmore brand refrigerators offer energy efficiency and space saving benefits with a range of innovative designs. The company's refrigerator-freezer units are manufactured in traditional top-mount freezers, bottom-mounts, and side-by-side styles. Occasionally, as with any brand of appliance, the components can malfunction and cause the freezer to stop working properly. A few troubleshooting steps can help locate the problem so that it can be repaired.
