Hey Fernando I think you are looking for a PVC valve, I have never heard of a pzv valve, look up 1995 toyota 4 runner valve cover replacement on YouTube and it shows right where the PVC valve is on the passenger side valve cover, good luck and god bless
Do you mean PCV valve? If so it should be right on top of the valve cover.
Engine stall or RPM fluctuates
at idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
