Question about Hitachi Deskstar T7K500 500 GB Hard Drive
Formatted hard drive but will not load linux
Can drive be formatted outside windows enviroment after being fromatted by windows xp to load linux???
    Brigadier General:
  • 3,917 Answers
I am not sure if you have another partition on the drive. If yes insert the xp cd first and delete the drive. Now try installing linux and while the installation point the deleted drive. It would automatically format it as per linux requirements and thus have both xp and linux installed on the same machine.
If you are talking about installing the linux on the same partition as of windows xp then the process would be different. You need to delete the partition using Partition Magic and then go ahead with Linux installation. Linux does not understand Fat32 or NTFS thus will not install on the xp partition without formating.
Thanks for contacting Fixya.
Posted on Jul 01, 2009
How do i uninstall windows 98 plus from my computer
You simply can not uninstall an OS (operating system), you may have to Format the hard drive itself. If you are upgrading the OS to a version that uses NTFS, like windows xp or higher, a format is suggested. If you have a boot diskette, you can do it that way. If not you can create on using windows 98, but you will need an old floppy diskette and a drive to boot. If you have a newer OS on a CD, simply insert into the computer and follow the on-screen instructions.
If you have a boot diskette(floppy), turn off your computer. Insert the disk and turn on the computer. Let it do its thing, once the diskette loads small programs, you will be able to format the HDD(hard drive).
you will see something like this after its done loading...
c:\
type in format c:
shown like this...
c:\format c:
A message will pop up, saying: WARNING! ALL DATA ON NON-REMOVABLE DISK DRIVE C: WILL BE LOST!
Proceed with fromat? (y/n)
If you are sure you want to erase everything, type in Y. The computer will now format (may take awhile) and will be ready for a new operating system!
Jan 30, 2012 | Microsoft Windows 98 for PC
I've got a 2 TB WD Elements external hard drive, and suddenly, no computer wants to recognize it when I plug it in. It is just rejected by any pc i've tried (3 laptops so far...) and I've a...
Is the PC you've used before is the operating system is windows Xp? If you've using windows Xp before then you've plug it in a windows 7 Operating system, it means your hard disc have no problem the operating system of your PC is different than before. Try to plug it in a windows Xp operating system then recover it in there then format it in a windows 7 operating system then, the windows Xp and windows 7 try to make a network place in the connection then share the hard disc files that you've recovered then copy and paste it in the newly format hard drive that formated in a windows 7 operating system.
Jul 21, 2011 | Western Digital Elements 2 TB USB 2.0...
This Disk is write protected
Hi!
if you use Windows XP or earlier, then - right click on your flash drive, goto "properties" -> uncheck "read only" checkbox.
If you use Win 7 or Vista - then use administrator account to run format (shift+right click on program, choose "run as administrator" ). the easiest way in Win7/Vista to format your flash drive is: Start -> all programs -> Accessories -> shift+right click on command prompt -> "run as administrator" -> type fromat driver_letter /q /y and press enter (e.g. if your flash driver has letter z, then you need to type format z /q /y and press enter). This will quickly format your flash drive.
If you use Linux/Unix/MAC OS, then you can use GParted or following command in terminal:
1. su
2. Enter password when asked
3. fdisk /dev/your_flash_drive_name (e.g. dev/sda/)
mkfs -t vfat /dev/your_flash_drive_name
Hope that will help :)
Jul 02, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to Install both XP and Linux?
I would install XP 1st then Open suse or Ubuntu. When you install either of these linux OS's ensure you install to another partition other than the windows one. Both installation routines will allow you to format the drive to the linux ext2 format and automatically install a boot manager (usually GRUB) which will allow you to select the OS you wish to boot.
Aug 09, 2009 | PC Mall Ubuntu 8.10 for Linux
NO OPERATING SYSTEM FOUND AFTER I JUST LOADED XP HOME AND ALL THE UPDATES FOR IT ?
Put your windows disc in the drive and reboot. It should allow you to boot from disc and then you can install as per on screen instructions.
You have basically erased the hard drive and the OS
For future reference, just put your install disc in and reboot, you will be given an option of upgrade, or install. By installing you will automatically format the drive.
May 07, 2009 | Computers & Internet
Installing windows
1. Windows 2000 / XP maximum hard drive size 137 gigabyte limit
This one was fun. To install a hard drive larger than 137 gigabytes on your computer you need the following:
a motherboard, such as the Gigabyte GA-7N400 Pro2 which support the 48 bit hard drive addressing. Only new motherboards can be counted on to support this.
Windows 2000 service pack 3 or later. Windows XP service pack 1 and greater have this support built in. I assume this isn't a problem with Linux at all...
Shalom
Aug 25, 2008 | Maxtor Hard Drive
Drivers required
SCSI Drivers are only an optional part.
This is not a problem with your driver floppies.
The problem is with the linux being preinstalled on the HD.
Linux uses many types of file-systems. Even if it was NTFS or FAT, it is most probable that windows xp cd won't be able to recognize it; because, it may use unsupported method of formatting.
What you have to do is;
1. Format the two HDs by either
  • Moving it to another windows or linux computer and fully formatting the Hard Disks using fat32 or NTFS (supported by windows). If it is a windows PC using for formatting, no problems. If it is a linux system, delete all partitions, and format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
  • By a linux installation CD and here too, format the drive in FAT32 or NTFS and here, ONLY CREATE ONE FULL PARTITION COVERING ENTIRE SIZE OF DISK.
2. Install the windows xp in it, using the same booting from CD Porcess. Here, you may or may not choose to install the SCSI drivers ( the floppy you got by pressing F2 when it says to do so in the installation immediately). It is good not to install the SCSI drivers if it is not a necessity for you.
Now, you can create any number of partition, format, etc during win XP installation.
Feb 18, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
New maxtor sata II/300 h/d installation
throw windows in the trash bin and get Linux !!!
goto Maxtor website and download one of their drive install/diagnose/format programs (such as MaxBlast 5). Run it making sure to select appropriate options for XP.
Dec 27, 2007 | Maxtor Hard Drive
Not able to install linux
My guess is that when installing XP the option to format using NTFS was accepted. You should get a (Windows 98) DOS start floppy/CD and re-partion and format the drive before booting Linux install from CD/DVD
Dec 25, 2007 | Computers & Internet
FAT32 format, how to do it in Windows XP?
Try using a third party program, like Norton Partition Magic, Acronis Disk Director Suite, or Paragon Partition Manager.
Nov 20, 2007 | Western Digital WDG1C2500N MyBook Premium...
Hitachi Deskstar  T7K500 500 GB Hard Drive Logo
69 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
