Question about IBM ThinkPad T30 2366 Notebook
Lan port not working , tried all normal options
IBM T 30 Lan port not working , tried all normal options looks like mainboard problem is this a common fault
  • 197 Answers
Try to re-install you network driver.
go to control panel, system maintenance, device manager. uninstall the previous driver downloaded on your machine then boot up machine. once done, install your network driver.
Posted on Jul 02, 2009
Belkin F5U307 Hub suddenly doesnot work on my Macbook
The lights (link light) on the hub indicate the LAN cable from the computer to the hub is connected and working.Disconnect the cable fron the hub and the computer then connect the Lan cable to the computer first and the other end of the LAN cable to the hub anf the link light for that LAN port on the hub should light up. If not the LAN cable could be faulty then try a different LAN cable.
NEXT
Try turning off the power to the hub for 30 secs, reconnect the power and check the LED lights. If this does not fix the problem then it appears the hub is faulty.
Apr 20, 2012 | Apple Computers & Internet
Driver mainboard PM - 865G1 REV 2.7
it's the same motherboard of IBM ThinkCentre M50 you can download all driver from the website of Lenovo. To make it quick download from here : http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-50534
cheers
Feb 07, 2011 | IBM 89P7663 Motherboard
We had a storm go through and now I have six Optipoint 420 Standard phones with the LAN port not working. I've reset the phone to factory settings, reapplied my configuration, and installed the 420std...
I have a hard time believing six would all fault the same way. I would first check your router/switch for problems which is common to fault on power spikes,(often fixed with a 1 minute power down) then check your phone servers connection. hope that helps you. cheers
Aug 25, 2010 | Siemens Optipoint 420 Standard Op420 Voip...
Module: x3200m3 type:7328 i7s server how many lan (RJ45) ports
Only two ethernet ports onboard. You can configure or add cards as per your requirement...
Please refer the graphic below;
Ibm System x3200 M2 server motherboard
Good luck.
Thanks for using FixYa.
Jun 28, 2010 | IBM System x3200 M2 Server
Bad sound from laptop speaker
To change the speaker, you would have to take apart the whole laptop because top bezel wouuld need to come off. As far as replacing the broken LAN port, you would need the exact LAN port. Meaning you would need to unsolderr the old LAN port an replace it with the new working LAN port. Either way you would have to take the laptop apart and to take off the top bezel.
Apr 19, 2010 | IBM ThinkPad A21m 2628 Notebook
Reset pswd
You can reset the unit to factory default... this will set the password to factory settings.. then you can create new password
Jun 16, 2009 | IBM Nways 8275 Model 217 Networking Switch
Printer driver for ibm wheelwriter needed
If the WW has the printer option (there will be a parallel plug on the back) it will most generic daisy wheel drivers will work.
DickyO
Apr 07, 2009 | IBM Wheelwriter 30 Typewriter
Ibm netvista trying to boot from a non-existant lan system.
With my netvista I was able to get boot options with F12 when powering up. I don't know if this will help you because I was installing a new hard drive. Larry
Mar 06, 2009 | IBM NetVista A40 PC Desktop
IBM ThinkPad T20
Wow, a lot of information but I'm unclear as to what you are trying to do.
Are you connecting the T20 directly to the T40 using a cat5 cable and then trying to access the internet on the T20 via the modem?
Connecting the two computer together using a normal cat5 will not work, you need to use a crossover cable otherwise you are connecting the send to the send and the receive to the receive.
You can also use a hub, a switch or a router if you have any of those on hand.
As for the modem, I suggest you unplug the telephone line from the modem and plug it into a phone and see if you can hear a dial tone. If you cannot hear a tone either the extension is bad (replace) or you outlet is defective. If you can hear a tone, the modem card may be defective.
Oct 08, 2008 | IBM Thinkpad T20 Notebook
Ibm think centre a 30
Windows XP has Drivers within the operating system to Install and setup USB Ports.
Here Are your options to Provide A Fix.
1: )The USB Port May Be Disconnected From The motherboard.
2:) The Device you are trying to Connect ( Pen-Drive ) May be faulty And Not Recognised By The Computer.
3:) The USB Cable Or Socket May Be Faulty.
Solution:- Try Connecting the Device To An Alternative ( different ) USB Socket On The PC.
Solution:- Try Connecting a Different Device to the USB Port. i.e MP3 player Or Digital Camera et,c.
Solution:- Check that the USB Header Cables ( from Motherboard To USB Ports ) Are connected Or incorrectly Connected.
Mike @ Compurepair.
*****Common Sense Comes As A Built In Feature*******
Feb 28, 2008 | Computers & Internet
IBM ThinkPad T30 2366 Notebook Logo
439 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
