Question about Dishwashers
Arcing noisewhen power is on and water leaking from underneath
  • 224 Answers
Your supply hose probably isn't tight. If you're using copper, switch to a braided supply hose. Are your electrical connections insulated? arc noise could be the an arc flash between the power connections and leaking water.
Posted on Jul 01, 2009
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
01 toyota avalon with codes PO300-306 car runs rough and idles rough now while driving it start loosing power and making a snake rattling sound
Is the rattling sound coming from the exhaust? I'm wondering if perhaps you have a loose catalytic converter. P0300 (multiple cylinder misfires) and P0306 (cylinder #6 misfire detected) are probably the cause as to why the car is sluggish, shakes, runs rough and lacks power. Make sure to take a close look at your ignition system (spark plugs, ignition wires, coils...). A spray bottle filled with soapy water can help you find voltage leaks on the wires and coils. Just spray the wires and coils and look for arcing. Replace any component that arcs. Other causes can be fuel injectors, vacuum leaks...).
Mar 03, 2013 | 2001 Toyota Avalon
Power vent rheem mod pvw50 underneath is leaking
You have a water leak coming out of side of tank?
Water heater must be replaced. It is rusted, and could rupture.
Inspect and replace anode rod to prevent rusted tank, so water heater will last longer.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Aug 09, 2012 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water leaking out from underneath
How to Fix a Leaking Dishwasher Hose. *. Whirlpool Dishwasher Connection ... the drain hose pushes water from the dishwasher without water buildup ...www.ehow.com/how_12089937_fix-whirlpool-dishwasher-leaks-underneath.html
hope this will help
Jan 31, 2012 | Whirlpool Dishwashers
Water leaking from underneath fridge
If you have a ice maker inside your freezer, check where the water connects to the back. I think you will find a leaking connection. Tighten connection to fix the leak.
Please rate this solution
Sep 06, 2009 | Frigidaire Refrigerators
Power Flo Matrix pump, leaking from underneath?
Replace the pumps mechanical seal with a replacement seal #200. It's less than $10.
Jul 19, 2009 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Gld5860l00ss QuietPower2 water leak
did you fix it yet ? check water line fittings underneath if you can pull a bit out washer to watch underneath when running to see where and when in cycle it leaks don't touch any electrical connections safety first LOL. disconnect power wipe dry and then ren it through a quick wash or other cycle and see.
Jul 10, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Dishwashers Logo
64 people viewed this question
Top Dishwashers Experts
