Question about Zodiac BARRACUDA G3 IN-GRND CLEANER
Baracuda pool cleaner does not cover the entire pool
My baracuda always gets stuck at the corner of the steps. My pool is kidney-shaped. I don't have any weights on the hoses nor do I have any valves at the end of the hose that connects to the skimmer.
  • 640 Answers
With these pool cleaners, there are several things that it could be. Check the return line water flow and redirect as necessary with an eyeball diverter. Make sure the automatic regulator valve is installed properly and is not clogged. Make sure the cleaner has proper hose balance.
Posted on Oct 26, 2010
Zodiak G4 Get stuck in corners steps ect.
Check a couple things when these pool cleaners are getting stuck on steps and in corners. Is the correct length of hose being used? It might be necessary to shorten. Make sure that the ideal flow is being achieved. Add hose weights 3 feet from the cleaner head. You might need to also install a wheel guard (part # W83278). This wheel delfector will also work if the cleaners are hanging on the ladder.
Apr 14, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My cleaner almost always get stuck on the white plug thing at the bottom of my pool, very frustrating its really not worth putting it in as it gets stuck almost immediately and stays there until I move it...
If the pool drain cap is recessed below the bottom of the pool floor, you can fabricate a plexiglas acrylic or polycarbonate cover for the cap. Measure the diameter of the recessed drain and add 4 to 6". Cut a circular piece of 1/4" thick acrylic/polycarbonate (you can purchase this at a home improvement store or glass company) to that diameter. Drill 10 or more 3/4" holes, evenly spaced, in the panel. The total area of the holes must equal or exceed the area of the drain caps openings. You can position the panel over the pool drain using a skimmer net extention pole. The pool cleaner will ride smoothly over the panel. Reaching the exact size and shape needed may be trial and error. I hope that I have answered your question and that this works well for you.
Dec 06, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Keeps getting stuck in corners
There are several things that you can try if your pool cleaners getting stuck at corners. First, make sure that the cleaner is getting the proper water flow and adjust it if necessary. Also, make sure that you inlets are adjusted so that they are pointed down and at the center of the pool. This will ensure that the cleaner is pointing in the right direction. Check your hose weights to make sure that they are correct. You will know they are right if the cleaner is sitting at a 45 degree angle with the pool's bottom when resting.
Nov 20, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Zodiac G2 gets stuck at far end of pool in two corners. Each time I have to pull the hose to get it out, then its fine. Anything I can do to stopit getting stuck in the first place, please?
The biggest cause of this is current in the pool driving the cleaner to the corners. You propally just need to change the direction of the eye balls on you returns to the pool. Face them down the pool wall or just in another direction to break up the flow of water in the pool.
Oct 07, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
I have a G4 unit. Can not get it to clean the shallow end. It likes to orbit the deep end mostly on a kidney shape in grd pool. I have change hose lenghts. I have moved the hose weight at different...
Try moving the water inlets around. Down the wall if you can. They will set a current in the pool the cleaner with floating hoses can't over come. If you don't have eyeball returns you can get diverters to do this for you. That should fix your problem.
Sep 27, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
My zodiac baracuda gets caught up in the corners of my pool constantly. What should I do?
If these pool cleaners are getting stuck on corners or other obstacles, try these solutions. Try using Pool Pulse to lower the flow. If you are getting too much flow, the cleaner will stay along the edges of the pool and in corners. You might also need to adjust hose weights. You can adjust your return flow lines in the pool. If they are directed toward the corners, try moving them down and center to direct the cleaner in the correct positions in the pool.
Aug 13, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Just wondering if my baracuda cleaner can be run with the pool cover on. In ground pool with steps.
Much better if you have the hoses that sink, not float. The action of the hoses rubbing on the cover will affect where the cleaner goes. I would suggest not cleaning while pool is covered.
Aug 04, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Get stuck in the pool corner
try adding a hose length or taking one piece off. Also you can try increasing or decreasing the suction.
Jan 15, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Baracuda gets stuck
Usually this can be fixed by redirecting thr returns in the pool down the wall or anywhere that will break up any currents in the pool.
Dec 30, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Baracuda G4 won't clean whole pool. goes to a corner and stays
Maybe your hose needs to be reprogrammed by unhooking and lying it in the sun for several hours.
Apr 25, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Zodiac BARRACUDA G3 IN-GRND CLEANER Logo
1,229 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
