Question about Sony GV-D1000 Mini DV VCR
Sony GV-D1000 Mini DV VCR - Does Not Power On...
When I power the switch to "on", the green light comes on in the POWER ON/CHARGE for about 3 seconds and then turns off. The machine does not turn on. Any suggestions?
    Problem Solver:
  • 6 Answers
Re: Sony GV-D1000 Mini DV VCR - Does Not Power On... - Sony GV-D1000 Mini DV VCR VCRs
Dead batt
Posted on Oct 22, 2009
0 characters
3 Points
Sony gvd 1000 wont work comes up with code c 31.10
The 31 indicates a motor movement problem. The 10 indicates which one. I don't have the manual handy so I can't look up the specific motor movement that is wrong. These units are tricky to work on and are not DIY repair machines. Please seek an authorized service centor for this repair.
Jan 18, 2011 | Sony GV-D1000 Mini DV VCR
I would like to buy a repair manual for the sony repair manual mini DV-1000 recorder player
Required service manual can be downloaded from HERE for small fee.
Hope this info helps you.
Jan 03, 2011 | Sony GV-D1000 Mini DV VCR
Sony gv d1000
Sounds like an exit guide mis-alignment or a worn pinch roller.
Jan 15, 2010 | Sony GV-D1000 Mini DV VCR
Wharfedale24hd250f stuck in set up mode will not resond to anything else
turn off power, unplug power cord, plug in, turn on and hit menu
Oct 22, 2009 | Sony GV-D1000 Mini DV VCR
Lost the cd rom disc SPVD-008
Check out the first link for your drivers. The second link is for your remote, they have one in stock. Just copy and paste into your browser.
Hope this helps. Let me know if I can help you with anything else.
Oct 04, 2009 | Sony GV-D1000 Mini DV VCR
Tape is playing but no display
check the tiny vcr switch on the back of the unit
Sep 08, 2009 | Sony GV-D1000 Mini DV VCR
Sony GV-D1000 Powers on, will play memory stik, but not tape
C:31:23 error code means problem is in Supply Reel section.
If you are tech person you might got the point.
Unit has mechanical problem in supply reel area and reel pulse is not being generated as supply reel table may be stuck due to back tension.
Let me know if you need further help.
Feb 11, 2009 | Sony GV-D1000 Mini DV VCR
For Info Lithium Battery only
I was having the same problem with a sony GV-D1000 which I don't even use a battery with. I use an AC adapter. Someone suggested that the contacts might be dirty, so I unplugged the small connector that plugs into the back of the deck and wiped it hard with my t-shirt. It seems to work fine now. SO try cleaning the contacts (wherever your adapter or battery connects with the deck or camera.)
Aug 11, 2008 | Sony GV-D1000 Mini DV VCR
Sony GV-D1000 unable to be recognized.
launch video editing should be able to see your deck. none of my three macs "recognize" the deck, but finalcut pro sees and can control the deck once it is connected and turned on
Nov 29, 2007 | Sony GV-D1000 Mini DV VCR
Sony GV-D1000 Mini DV VCR Logo
147 people viewed this question
Top Sony VCRs Experts
Andy Fraser
Andy Fraser
Pieter Vleeshouwers
Are you a Sony VCR Expert? Answer questions, earn points and help others
