Question about KLH Audio Players & Recorders
I have a KLH subwoofer from 1992. It has started to make a buzzing/rattling type sound. Should I take it in for service?
    New Friend:
  • 58 Answers
Yes... At best it may be just a loose mechanical fixing component or foriegn object :)
Posted on Aug 18, 2014
SOURCE:
  • 5 Answers
SOURCE: loud humming buzzing sound coming from subwoofer
make sure you have the speaker connection right if you do then it is a ground problem try plugging it in a different outlet
Posted on Dec 16, 2008
SOURCE: it is a klh powered
I have a KLH Bassbite II that has always had a hum when turned off. It never seems to heat up so i never really worry about it. It is strange. Off should meen off!
Posted on Dec 13, 2009
SOURCE: KLH ASW10-120 Subwoofer My KLH ASW10-120
Did you ever find a solution for this problem? I have the exact same thing happening with my KLH subwoofer and I'd love to know how to fix it!
Posted on Jan 26, 2010
dunnbiker
  • 8546 Answers
SOURCE: KLH subwoofer Model BASSBite V. Has a bad 60Hz buzz
Before you go throwing money at this problem, try to eliminate any external influences like track lighting. I myself am trying to figure out why mine makes a buzz throughout my system when the lights are on. I already replaced the variable light control with no improvement.
Bad cable ground can let airborne electronic noise into the Sub's amp.
Posted on Jan 31, 2010
Grubhead
  • 5686 Answers
SOURCE: klh subwoofer asw12 200 powers on but no sound,
There's an amp inside the unit, most likely the semicondutor that does all the work has failed in it.
Posted on Feb 01, 2010
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
SW-910, blown speaker or ? makes rattle/buzz sound. replace speaker and/or change to passive type sw?
i would suggest replacing it rather than fixing. The cost of the repair will be about the same.
if you went to a passive sub/seperate power amp setup you could get a much higher quality unit, but it would cost you considerably more cash.
Feb 01, 2015 | Sony Audio Players & Recorders
I have a KLH subwoofer which is connected to my reciever and speakers with speaker wire. It is not connected to an outlet. It has recently started making a buzzing/rattling type sound. Do I need to take...
Yes, probably, if you aren't capable of repair yourself. However, IMHO, a replacement will probably cost less in the long run. I have a KLH passive subwoofer myself. I wouldn't pay for any repair if it failed. Replacements are far too inexpensive.
Aug 18, 2014 | KLH Audio Players & Recorders
I turn on my subwoofer and the volume is turned down and it makes a loud buzzing sound, and its not even hooked up to the amp, just pluged in. Thank you, Joel Arntsen
You might have blown the speaker. This happens when you play things too loudly and you ruin the speaker inside. You can test this by playing something with a decent amount of bass and turned up a bit. If you hear like a "rattle" in the sound or like something isn't right in the heavy bass notes, then you definitely blew the speaker out. This isn't a tragedy. They're fixable if you bring them to a place that repairs speakers. But I would definitely test it first by hooking it up and playing a loud song with a lot of bass. Hope that helps a little! Please rate my solution!
- Frankie
May 06, 2011 | KLH ASW10-100 Subwoofer
My subwoofer constantly makes a steady intermittent buzz sound while plugged in, even while powered off.
If it has a 3 prong plug, try a 3 prong adaptor - where only 2 prongs are plugged in. Sub's should not be grounded. If it still makes a hum noise, the amp circuitry may be compromised. Replace the amp with an equal at www.partsexpress.com
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Dec 06, 2010 | KLH PSW8100-8 Subwoofer
Jan 31, 2010 | KLH ASW10-120 Subwoofer
Dec 26, 2009 | KLH ASW10-120 Subwoofer
It is a klh powered subwoofer, which buzzes when plugged in, even though the power switch is set to "off"
Sounds like the grounds are screwed up. Try using a grounded wire for the subwoofer input. If that doesn't work, it sounds like something is internally screwed up, like the power supply doesn't fully power down. I guess besides buying a new amp, just connect it to a power strip where the switch is accesable and shut the sub off with the power supply.
Oct 10, 2009 | Audio Players & Recorders
Loud humming buzzing sound coming from subwoofer
Dec 16, 2008 | KLH HTA-4906 System
Subwoofer no longer produce base sound
Master witch is blown. Also the frequency control swithe is probably gone. No replacement parts available. contact KLH at 818-767-2843
Dec 03, 2006 | KLH ASW12-200 Subwoofer
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
