Question about Astar LTV-3201 32 in. LCD Television
Astar LCD HDTV Monitor
The model # is LTV-3001 and the serial # 6505000195. I purchased this item a little over a year ago and recently it will not come on. I only use it for TV purposes with basic cable, nothing else connected. Is there a reset button?
  • 51 Answers
Re: Astar LCD HDTV Monitor
The set has Electrolytic capacitors that have gone bad. The problem began with poor cooling and even poorer design. Most local shops should be able to do the repair. I have ran a Television repair shop for many years and experience the same problem with many different brand lcd tv's.
Posted on Mar 17, 2008
Mine also does the same thing on a 30' model and have found out it is a burned out power supply....unfortunately i have been unable to find repair parts because the company has been forced out of business...
Posted on Feb 04, 2008
0 characters
3 Points
I need a replacement circuit board for my Astar LTV-3001.. Mine began to smoke... and I don't allow smoking in my house...
The failures on these LCD's are due to defective capacitors in the power supply. There are about 23 capacitors that will need to be replaced to restore the LCD power supply functionality. Check the picture to see where the capacitors are located, the power supply on your LCD is not the same but similar to the one on the picture just the capacitors are place in a different order.
Let me know if you required further assistance.
Mar 10, 2010 | Astar LTV-3001 Television
Astar 27" TFT LCD TV, Model LTV-2701
go to and enter your model number and purchase a factory replacement
Nov 25, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
No sound when tv switched to dvi Astar model LTV 3001
There is no audio in DVI connector, you need to run separet cable for audio signal.
Dec 30, 2009 | Astar LTV-3001 Television
Astar 30 inch model ltv-3001 will not turn on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to
Jan 20, 2009 | Astar LTV-3201 32 in. LCD Television
I didn't get a manual when I purchased my TV
I have worked as an Electronics Tech in Astar before closing and I have collect all the model information, hope this is help.
At this point I only have the Astar model manual; 19bg, 2001, 20PW, 20SD, 26ASB, 27ASB, 32ASB, 26OB, 3001, 3201, 32BG, 32HBG, 37HBG, 42HBG.
I will update on the LTV-2701 by contact me at 323-767-6030
Dec 01, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Astar 32'' LCD - anyone have monitor drivers?
I purchased this model
and have been able to get 720p and 1080i resolutions on DVI connections from my PC with both Intel and ATI graphics AND 1920x1200 resolution over VGA from the Intel integrated connection (the ATI has only DVI). You need to dump the EDID to see what resolutions and timings the TV is telling the video card it supports. Then you need to get a video card driver that allows for custom resolutions to be created. First download this free utility and post the output:
Nov 16, 2008 | Astar LTV-3201 32 in. LCD Television
Astar LTV-3001
That was the power supply failing on yout TV.
You will need to change it or get it repair.
May 18, 2008 | Astar LTV-3201 32 in. LCD Television
Have you guy check the power supply for your TV?
Call me 323-767-6030 and I will go through with you.
Feb 06, 2008 | Astar LTV-3001 Television
Astar Plasma
try to contact my friend Ivan 323-767-6030. He had working for the astar company as electronic tech maybe he can help you and answer all the problem of your astar tv.
Thank you.
Jan 25, 2008 | Astar LTV-2701 27 in. HD-Ready LCD...
Astar LTV-3201 32 in. LCD Television Logo
117 people viewed this question
Top Astar Flat Panel Televisions Experts
Jaime Hernandez
Are you an Astar Flat Panel Television Expert? Answer questions, earn points and help others
